Problem starting
Old Dec 12, 2010 | 09:34 PM
RhondaBruce's Avatar
RhondaBruce
Problem starting
Recently when I turn the key, my truck has been cranking slow and with maybe one revolution before it dies and starts clicking. I get a jump and it starts fine with the volt meter looking normal. Should I be looking for a faulty starter relay or solenoid? It is a 5.0 efi (maf).
Old Dec 12, 2010 | 09:52 PM
95f2504x4's Avatar
95f2504x4
thats more than likely the battery
Old Dec 12, 2010 | 10:36 PM
RhondaBruce
Wouldn't it stall out if the battery dies and becomes unchargable? The voltmeter also says everything is fine. Also when ive been jumped the cables were not connected long at all.
Old Dec 13, 2010 | 01:02 AM
diamond mike's Avatar
diamond mike
make sure lead to starter tight mine wasent and i just dicovered it today {similar problem
Old Dec 13, 2010 | 07:48 AM
Nathan Plemons's Avatar
Nathan Plemons
If everything is working fine you can disconnect the battery after it's running and it will still run just fine. Battery would be my first suspect. If the battery is fully charged it should read approximately 12.8 volts with no load. If it is healthy it shouldn't drop below 10v while cranking. It's kinda a poor man's load test.
MudhenGIB
Jan 26, 2013 09:09 AM
Docwho
Jul 22, 2012 12:42 PM
tperk100
Nov 1, 2011 05:17 PM
2006powerstroke90
Jan 18, 2011 09:13 PM
