Block Heater Cord Connection?
Old Dec 12, 2010 | 07:22 PM
hikeril's Avatar
hikeril
Based on searches I have determined that all diesels have a block heater and all I need to do is purchase the cord. Has anyone purchased the cord and installed to the existing block heater? My truck did not come with the block heater option. I looked on page 30 of the 2011 6.7 diesel brochure to see the heater and with further research I have determined where it is located on the engine. Based on the pics I am unable to find it. In the pics it is really easy to locate however when under the truck it appears as though the starter is in the way of locating the connection. I have felt around to see what I can find but seem to missing it. Any help would be appreciated. I am traveling from St Louis to Fargo and Bismarck ND for xmas and realize I will need to plug in with temps at night falling below 0. I would like to do the install myself to avoid paying labor but if I am unable to locate the connection I may need to pay the price.
Old Dec 12, 2010 | 07:42 PM
srkr's Avatar
srkr
Bump, I'll be watching this thread also.
Shane
Old Dec 12, 2010 | 07:47 PM
RBolton6's Avatar
RBolton6
On pg 11 it shows the location. I had similar ideas and asked about price of just the cord. Guess what? It's basically the same as the entire heater ~$100. FORD is really proud of those cords! As I recall though I could see the heater location from the wheel well. Didn't get the cord yet.
Old Dec 12, 2010 | 08:22 PM
11350KINGRANCH's Avatar
11350KINGRANCH
It's there. I got a cord, but have not routed it up the frame yet. I am going to try to remove the wheel well insert to give myself some working room.
Old Dec 12, 2010 | 08:25 PM
don.joyce59's Avatar
don.joyce59
I guess I'm confused about the cord. Mine has a cord that is behind the grill, at the right side. If I use the block heater I intend to use a heavy duty extension cord to plug into the outlet in the garage.
Old Dec 12, 2010 | 08:37 PM
kper05's Avatar
kper05
Is this cord simply "plug and play" (appears to screw on) to the block heater?
Old Dec 12, 2010 | 08:45 PM
cford716's Avatar
cford716
They did not get the engine block heater option from the factory, therefore they do not have the cord that comes from the block to the front grille. Apparently all the engines have the heater, it is the cord that you see at the grille that you are paying for when you order the option.
Old Dec 12, 2010 | 09:06 PM
kper05's Avatar
kper05
EDIT: Appears it doesn't come on all engines!
Last edited by kper05; Jan 23, 2011 at 04:11 PM. Reason: Check my engine, no heater element...
Old Dec 12, 2010 | 10:18 PM
Tom's Avatar
Tom
Remember that it's not a high-wattage element. My George Foreman grill uses more electricity than this thing!
The block heater only uses 900 watts.
Old Dec 12, 2010 | 10:39 PM
rickatic's Avatar
rickatic
interesting comparison between 2 heavyweights...
Old Dec 13, 2010 | 11:50 AM
Fat_Tire's Avatar
Fat_Tire
You can see the location of the block heater element from the wheel well just above the starter but not all of us have an element... I don't... and there have been several other reports of no element installed. If you didn't order the optional chord, there is a chance that you may not have the element... even though it is supposed to be standard on all blocks.
Old Dec 13, 2010 | 05:27 PM
Paratrooper84's Avatar
Paratrooper84
Can someone get a picture of the block heater element. I have literally crawled all over the place looking for the block heater and had no such luck locating the heater. When I took it in for an oil change at the Ford Dealership, I had the mechanics crawl all around looking for the block heater. They finally came back and said its not there and that if my window sticker didnt say block heater on it that the truck did not come with one. ( My sticker DID NOT say block heater). My salesman did however tell me that it was standard on all trucks that are bought in the northern states.(I bought my truck just East of Toledo Ohio, and thats why I didnt request it when I built my truck).
Any help would be great. I'm heading back to Michigan in a couple weeks and would like to be able to plug her in when I get home.
Thanks,
Old Dec 13, 2010 | 05:44 PM
720Deere's Avatar
720Deere
Don't feel bad, not only did I pay for the option and not get it, but there is a socket head plug in the place where the so called standard heater element is supposed to be. If indeed the actual heating element was standard as it is supposed to be, the cord is cheaper from the parts counter than the $75 option on the order sheet.
My brother's truck came out of dealer stock and didn't have a cord so he bought it from the parts department for under $50 as I remember. He hasn't tried to install it yet, I bet he doesn't have a heating element either.
Old Dec 13, 2010 | 05:51 PM
Paratrooper84
Thanks for the support. I do see the socket head plug I believe you are talking about and thats why I asked for some help from the mechanics at the Ford dealership. About 5 mechanics came over with flashlights and started looking. I'm in Atlanta, Georgia and this was the first 6.7 engine they have ever looked at. ( I know they did my oil change...scarrrrryyy!)
Old Dec 13, 2010 | 06:21 PM
cford716's Avatar
cford716
Thanks,
From the list of options: Engine Block Heater (Std. in AK, CO, IA, ID,
ME, MI, MN, MT, ND, NH, NY, SD, VT, WI,
WY)
Ohio is not listed ( don't ask me why not ) but your dealer should have known this. You may want to take this up with your salesman.
