GVWR
Old Dec 12, 2010 | 05:06 PM
Country705's Avatar
Country705
GVWR
I got a build sheet on dumplin and it says that its GVWR is 6001-7000. that seems like alot is this right?
Old Dec 12, 2010 | 05:40 PM
jroehl's Avatar
jroehl
Sounds about right. It should be around 6100 or so. Check the sticker on your driver's door (or jamb, I can never remember which it's on). The GVWR will be listed there.
Jason
Old Dec 12, 2010 | 09:36 PM
88n94's Avatar
88n94
Your truck and the driver would weigh in at around 5000 pounds, so that wouldn't leave you so much payload. You can usually exceed the GVWR by quite a bit with no problems though.
