06 Alignment
Old Dec 12, 2010 | 04:56 PM
padyt562's Avatar
padyt562
06 Alignment
NOOB here. Just got an 06 f150 crewcab, 4.6L 26,000 orig. miles. My problem is the front drivers side tire is wearing on the inside. The tires are the orig "Hankook"? I just rotated them and think this is the first time they have been rotated. Nothing loose or bad in the steering. I noticed there is a TSP #05-26-7 for this problem but I can't locate the full text. If anyone could share this info it would help alot. Also I can't find the alignment specs. Thanks for the help.
Old Dec 12, 2010 | 05:58 PM
danorules's Avatar
danorules
it is 5 years old and i am sure it has hit some bumps along the way. i believe you just need an alignment, no problem with the truck, just regular maintenance
Old Dec 13, 2010 | 07:38 AM
ford390gashog's Avatar
ford390gashog
Just have an alignment done on the truck. Worst case you will need new tires or maybe its a lower ball joint going bad. But just have an alignment done. MAKE SURE THEY USE A LASER GUIDED alignment machine like Hunter don't settle for the old crap. Without it these trucks are very hard to align most LesSchawb centers all have it and some Ford dealers have access to them.
txgp17
15
Apr 26, 2011 07:50 AM
robinpy
1997 - 2003 F150
Jun 13, 2004 10:52 AM
99Motorcraft
Sep 4, 2003 12:50 AM
