Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
code PO356ign.coil F?
Old Mar 31, 2011 | 09:24 AM
  #31
wptski's Avatar
wptski
There was a TSB back some years ago about OEM plugs taking out COPs and at times the drivers in the PCM.
Old Mar 31, 2011 | 10:30 PM
  #32
markstertt's Avatar
markstertt
Tom and Bill,
Thanks for the replies, I'm not sure where I'm at with this, I've opened, cleaned & dielectric greased all the reachable wiring plugs on the engine and that's quite a few. I've swapped coils 5 & 6 and wiggled everything in site with car running to know avail. I would think if the PCM was bad (driver, whatever) that it would be less intermittent & I don't think I want to open it up since it is covered under the 8/80 emissions warranty. The last 2 days I've done 30 mile freeway runs at all rpm's up to 80 mph, cruised at 75 mph and 3500 rpm with a/c an o/d off & not a burble, no codes nada. However, just tonight when checking hot tranny fluid level, I noticed a clacking sound coming from the water pump pulley end of the front cyl.s intake cam. Screw driver to the ear test sounds the loudest right at the bump in rocker cover over the last camshaft bearing cap before the cam exits the cover to the water pump pulley. Looking at the service manual engine pixs, I don't see anything right there that should clack. Looks like another post search is in order to see if this is a problem area. May pull a rocker box tomorrow...Mark
Old Jul 3, 2013 | 10:42 AM
  #33
raifleet's Avatar
raifleet
Question f-250 van with a po356 code
at first it had a p0352 code.so i checked wires&wiring,all look good changed #2 coil ran good.now ck.eng. light back on,never ran bad or anything with a p0356.I dont wont to replace a different coil ever time.any ideas.52.000 miles.it has done in past but clear up.just cleared code.p0352
97' DieHardExploder
Oct 30, 2014 09:57 PM
xFordGurl
Aug 31, 2012 02:19 PM
mniewald
Jul 26, 2011 04:46 PM
Mike-11
Jan 29, 2011 01:53 AM
smotherss
2004 - 2008 F150
Mar 15, 2010 08:48 AM
