oil filter question
Old Dec 12, 2010 | 09:31 AM
RRranch's Avatar
RRranch
oil filter question
I was looking for a better oil filter for our trucks and came across the LF9027. It looks like about the best we can get but I don't find much info on it for powerstrokes like ours. There is a lot on the LF3630 which is the standard but this is the venturi model with the stacked disc and stratapore elements inside. Any thoughts on it?
Here is some more info. http://www.cumminsfiltration.com/pdf...es/LT36043.pdf
Old Dec 12, 2010 | 09:52 AM
kawa's Avatar
kawa
Talking
Read the link below. TJ has done some research and has used these filters on his rig. Admittedly I didn't read the whole exchange but it was interesting to the point that I stopped. Retail, these filters run approx. $35.00 a pop.
Rog
Fleetguard Venturi Combo Filters?? - Bob Is The Oil Guy
Old Dec 12, 2010 | 10:10 AM
RRranch's Avatar
RRranch
Those guys are all bothered over what one filter salesman said it seems to me.
I liked stack disc filters though. I was a navy engineer and sat on the lower level many days watching an old deleval purifier work. Then cleaning it. That thing worked much like this filter but was lots bigger and run by a steam turbine. It was amazing the crap it pulled out of our lube oil. The navy never changes lube oil in the engines either. Most of my ships were more than 40 years old too. We just filter, settle and purify it. Then add to it due to leakage. That's it.
Old Dec 12, 2010 | 11:20 AM
plgebbia's Avatar
plgebbia
I always use the Motorcraft FL-1995 filter. Do you think that isn't sufficient?
Old Dec 12, 2010 | 11:35 AM
kawa's Avatar
kawa
Talking
It appears that they have been up to this point. How many power stroke engines do you read about that have failed do to insufficient lube related directly associated to filter failure? JMHO
Rog
Old Dec 12, 2010 | 03:37 PM
RRranch's Avatar
RRranch
Most things can be better is all my point is. Some things just get worse the more they are tinkered with though. I think the filter technology has started making a good comeback since the fl1995 was designed. That donaldson ELF7405 looks like another winner too. I need to check it out more.
Old Dec 12, 2010 | 04:21 PM
Muktown's Avatar
Muktown
Have you looked into an oil centrifuge? I heard about then but haven't done any research
Old Dec 12, 2010 | 07:48 PM
tjbeggs's Avatar
tjbeggs
The venturi filter is a waste of money! Check the specs on it. The full flow filter is only rated at 30 microns absolute and the stacked disc is 10 micon nominal (50%) if I remember correctly. my cost was $30 some bucks and it didn't do that much better of a job filtering than a Wix 1734.
tjbeggs's Avatar
tjbeggs
A dedicated bypass filter added on is the only way to go if you really want more filtration. Been there done that.
smokersteve
Oct 26, 2013 06:23 AM
bettousai
Feb 17, 2007 04:40 PM
sierraben
Jul 17, 2006 08:54 PM
llhol
Oil & Lubrication
Mar 16, 2005 10:25 PM
tmod
Jun 18, 2002 08:56 PM
