Question?
i need a motor and found one for $50 bucks but its from an 81 mercury grand marquis. i want to know what i will need to change so i can use it in my f150
You may find some little pieces are different, like the upper radiator hose neck, and a few brackets here and there, most of which can be modified to fit.
One thing to watch out for You are right in the middle of the years where they switched the balance of the 302 engines. Early engines are 28 oz inbalance while later engines are 50 oz inbalance. This happened around 81 or 82, so look at the flywheel or flexplates carefully for each engine. If you are not certain, take the flywheels to a machine shop to get them identified if you need to swap them from engine to engine. If you do not need to swap flywheels and can keep them with the engine they came with, that's the best bet.
o and my pickup 302 runs real good but all the fluids leaks.
Now when it idles you can hear a loud knock knock knock knock and when you throttle up the engine it evens out and sounds great. i think theres a bad bearring on the lower end toward the front of the motor.
ive been running 20w 50 wal mart brand oil to try to keep things lubed up real good and have also poured in lucus oil aswell, you know cause im trying to buy some time.
well anyways got to go thanks for info.
