1984 ignition key problem? broken spring?
Old Dec 11, 2010 | 10:40 PM
gwhpnut's Avatar
gwhpnut
Can anyone tell me if they have ever had this problem with an ignition key, and how to fix this? I turn the key to start the truck, it turns easy, but it will not spring back to the accessory position, unless you turn it back yourself, it will keep the starter in-gauged. I went to the parts store to look at a new switch, but I do not see that the new tumbler has a spring or any way to bring it back to the run position either? Is there a spring further inside the column? even looking at the actuating arm picture at the store, (a part they can't get) it doesn't look like it has a spring either? My question is, what am I looking for and what part do I need? I did not try the new tumbler as I thought I would ask first, and to me, it did not seem like the part I needed? any help would be appreciated, victor
Old Dec 12, 2010 | 04:05 AM
Lazy K's Avatar
Lazy K
The spring should be in the ignition switch which should be bolted to the top of the steering column under the dash. Remove the two bolts holding it and work it by hand, if no return spring then replace it.
If you do need to fit a new one note that, with the bolts loose, you can slide the switch up and down the column a little for final adjustment.
Old Dec 12, 2010 | 06:50 AM
gwhpnut's Avatar
gwhpnut
Thank, Lazy K
Thanks, for the help, I'll try that!, Thanks, vic
Kwikkordead
141
Apr 26, 2020 07:10 AM
66f-100
13
Nov 26, 2013 09:59 AM
ride_gnu
Jun 13, 2013 04:25 PM
2009 Convert
Apr 29, 2009 11:09 AM
lostbuckaroo
Feb 23, 2003 10:32 PM
