General Automotive Discussion
Snow plow question
Old Dec 11, 2010 | 08:07 PM
WINGNUT-'s Avatar
WINGNUT-
Snow plow question
I have a Fisher plow set-up that runs off a hydraulic pump that is powered by the engine. This is the first plow truck I have ever owned, so I am not sure what is normal operation and what indicates that something is wrong.
In my opinion, the plow tends to lift very slowly. And when their is a lot of snow stuck to the blade, it will barely lift. I will then need to kick the snow off in order to lift it. And it doesn't lift that high to begin with. Is this normal for an engine driven pump versus an electric pump? Or is the pump worn out? Has anyone dealt with this problem before?
Old Dec 12, 2010 | 01:02 AM
Ford_Six's Avatar
Ford_Six
Make sure the valve linkages aren't worn. If they are worn, you won't be able to get full travel and full flow in the hydraulics.
Old Dec 12, 2010 | 10:03 AM
WINGNUT-'s Avatar
WINGNUT-
Are these located on the controller, or on the valve body under the hood?
Old Dec 12, 2010 | 11:35 AM
fellro86's Avatar
fellro86
That would be the valve body. Also, the type of fluid matters, some get thick in the cold, and cause trouble as well. It could possibly be the pump though. Water contamination can also be the cause, fight that on some of our tractors. Heat the fluid, and it works fine until the next time...
Old Dec 12, 2010 | 12:44 PM
Ford_Six's Avatar
Ford_Six
Yeah, I didn't think of that. AW hydraulic fluid stays thinner than ATF, and there are also some special plow hydraulic fluids.
Old Dec 12, 2010 | 05:21 PM
cdrmotorsports's Avatar
cdrmotorsports
Check the fluid first, make sure that it isn't milky or contaiminated in any sort of way. Even with the older Speedcasts like yours, it is not normal for it to lift under strain like that. check out this website for more info and help under the Fisher Plows section:
plowsite.com
Old Dec 12, 2010 | 06:16 PM
WINGNUT-'s Avatar
WINGNUT-
I operated the plow today in 40* degree weather and it was able to lift a little bit higher and move somewhat quicker.....still not great though.
When I bought the truck the plow pump was filled with Advance Auto GM DEX 3/M transmission fluid, and that is what I am currently using. I checked it today and the fluid is bright red, not milky in any way.
I also checked the valve linkages and all seems well.
Old Dec 12, 2010 | 06:31 PM
rt2000's Avatar
rt2000
just tossin out an idea... it could be a dirty or sticky releif valve.if it sticks partially open it won't maintain normal system pressure,i've had this happen on an older tractor.
Old Dec 12, 2010 | 06:46 PM
mantta's Avatar
mantta
Is your pump belt driven? If so, make sure it is tight.
Plumberdude3
Apr 4, 2015 05:54 AM
PTL.PARKS
Dec 16, 2011 02:34 PM
JMyers0901
Sep 29, 2011 07:05 PM
jlaudio_f100
Jun 17, 2010 05:37 PM
firefytr29wfd
Jul 2, 2007 10:22 PM
