4 Wheel Drive Question
Old Mar 3, 2003 | 09:16 AM
TERMN8R's Avatar
TERMN8R
Question 4 Wheel Drive Question
When I take it out of 4 Hi - with the hubs in auto - it pulls to the right for about a mile. Any ideas? Thank you.
Old Mar 3, 2003 | 11:17 AM
bluecon1's Avatar
bluecon1
Sounds like the one hub may not be disengaging. I've got a new 03, and my hubs don't engage at all. Any thoughts out there? I've got a bunch of Super-duty's with ESOF, and never a problem.
Old Mar 3, 2003 | 11:42 AM
jschira's Avatar
jschira
The engagement is vacuum operated. If 4x4 is not engaging, you might have a problem with the vacuum lines.
Old Mar 5, 2003 | 04:19 PM
joeljohn69's Avatar
joeljohn69
Funny thing, I posted here last year because I didnt think my hubs were working correctly and I was told I was crazy. Maybe I am.
But.
I took my Ex to a real 4x4 shop rather than the dealer. He told me he sees these axles all the time and the vacuum hubs are junk. His opinion. To check his theory I went back to the dealer and test drove 3 used Ex's. 2000-2002. NONE of the 4wd worked! In fact on all 4 (including mine) the manual to auto lever is seized.
I pulled the vacuum hubs and installed manuals. Knowing they work is worth the inconvenience. Bluecon must just be lucky with those SuperDuty's.
Old Mar 5, 2003 | 05:05 PM
bluecon1's Avatar
bluecon1
I got my X out of the shop today. There was a broken vacuum "tee" on the actuator (sp), so they replaced the actuator. They also replaced the left hub, as it was not sealing the vacuum properly. Seems to work fine now.
Old Mar 5, 2003 | 05:50 PM
ted414's Avatar
ted414
This is my first vehicle with 4 wheel Drive. Other than the indicator light, how do I know if they are working correctly or not?
Thanks
Ted
2002 V-10
Old Mar 5, 2003 | 08:07 PM
Monsta's Avatar
Monsta
Sit. Stay.
Hmmmm....
Well when you put it IN 4WD, it should feel different when you drive. More pull. To make sure that the hubs are locked you can always turn full lock. These solid axle trucks just love it when you do that. The U-joints will bind.
Also, if the transfer case is not engaged...well...you'll still be spinning the rears (more than likely).
To ensure that all is DISENGAGED properly (a bigger prolem with mine) is to physically reach behind the wheels and try to turn the halfshaft. If it doesn't move and the switch is in 2WD, then try rotatin' the auto/lock "switch" on the hub back and forth a few times.
That help any?
351slug
Offroad & 4x4
Mar 16, 2013 10:11 PM
Irish816
Offroad & 4x4
17
May 19, 2010 08:08 AM
Offroad & 4x4
Dec 9, 2006 09:03 PM
4x4x4x4
28
Dec 16, 2002 01:54 AM
CustomCab4x4
Feb 3, 2002 02:20 PM
