Sponsored by: Auxito
How ID PI heads.
Old Dec 11, 2010 | 01:53 PM
Hybris's Avatar
Hybris
How ID PI heads.
In my wish list making for modding my truck I have wondered how to tell if I have PI heads.
The build sticker inside the door says if I remember right 10/98 so don't know if I have the PI heads or not, if I don't have them how difficult could it be to swap for the PI heads or would it be better to go to a aftermarket head design like Trickflow?
Old Dec 11, 2010 | 02:20 PM
phil6608's Avatar
phil6608
Look on the side of the head. Ware the number is it will have PI there too.
The only way your going to move as much air as the trick-flows is with a stage 3 port and bigger valves.
In other words,,,you cant hardly match the power of the Trick-flow heads.
Old Dec 12, 2010 | 07:36 PM
Hybris's Avatar
Hybris
Forgive me but where exactly is the number stamped? Pics of where to look would be great if possible.
Old Dec 12, 2010 | 08:32 PM
Ron W.'s Avatar
Ron W.
Originally Posted by Hybris
Forgive me but where exactly is the number stamped? Pics of wear to look would be great if possible.
On the driver side valve cover there will be a white decal with numbers on it, post what is there and I will be able to tell you if they are P.I. or not.
Old Dec 12, 2010 | 08:57 PM
jgeese's Avatar
jgeese
Question
What are "PI" heads?
Old Dec 12, 2010 | 10:16 PM
phil6608's Avatar
phil6608
Right over top of your exhaust header/manifold. On the side of the head.
Old Dec 12, 2010 | 10:21 PM
phil6608's Avatar
phil6608
PI = performance improved.
Your truck should have them Jeff.
They started putting them on the 5.4 in 99 and I'm not sure on the 4.6 but I think it was in 2000 or 2001.
Old Dec 12, 2010 | 11:31 PM
jgeese's Avatar
jgeese
Cool! Thanks Phil...
Old Dec 13, 2010 | 11:27 AM
Hybris's Avatar
Hybris
Couldn't get in to a postion to see the casted numbers but here are the numbers from the white decal on the driver side valve cover as its printed there.
9G876AA
FORD WINDSOR ONTARIO PLANT
982741631
455 10-01-98 54L
Again thanks for all the help so far.
Old Dec 13, 2010 | 07:38 PM
Hybris's Avatar
Hybris
Bumped to make sure it doesn't get buried.
Old Dec 13, 2010 | 08:27 PM
phil6608's Avatar
phil6608
Dose your 99 have an aluminum intake manifold?
Old Dec 13, 2010 | 09:42 PM
Ron W.'s Avatar
Ron W.
9G876AA
982741631
455 10-01-98 54L
9G876AA Is P.I.
Old Dec 13, 2010 | 10:00 PM
Hybris's Avatar
Hybris
Yes it does appear to have them.
9G876AA Is P.I.
Thanks for the help Ron.
CBR1000RR
Modular V10 (6.8l)
Jul 7, 2017 06:00 AM
imabass
Modular V10 (6.8l)
May 24, 2017 04:32 PM
MoJensen87
Sep 6, 2015 06:58 PM
redrock82002
Modular V10 (6.8l)
Jun 11, 2013 06:47 PM
1998Nascar
Modular V8 (4.6L, 5.4L)
Jan 19, 2012 10:01 AM
