Hello,
I recently got my truck back from getting the bed plate leak fixed. They pulled the engine to do it. I now have a vibration when I shift into reverse when the truck is cold, and it takes longer for the transmission to go into gear. I also had the transmission serviced at the same time. The vibration can be felt throughout the cab. Any ideas what would cause this? It did not do it before I took it in. I will take it back to the dealer as soon as I make sure it does it consistantly. I have only had it back for two days. Thanks for any help.
2006 F350 6.0 CC LWB 4x4 Lariat with auto trans
