'77 f150 overheating
Old Dec 11, 2010 | 08:46 AM
farmerwill's Avatar
farmerwill
Unhappy '77 f150 overheating
I have a '77 f150 4x4 with a 400 4 speed. My problem is at idle the truck runs at normal operating temperature. When I drive it, the temperature gauge climbs to hot. If I let off the gas and push in the clutch, the guage returns to normal range. I believe it is overheating because of the way it runs when the gauge climbs to hot. I have checked coolant and I have no loss. I replaced the thermostat twice, going with a cooler one (180) the 2nd time. I replaced the sending unit thinking it was messed up. The radiator seems to be holding pressure but just for fun I replaced the cap. None of that helped. Any ideas or suggestions would be greatly appreciated.
Old Dec 11, 2010 | 10:24 AM
jplinville's Avatar
jplinville
Chemical flush time. Sounds like you have some scale buildup in the water jackets causing a restriction.
Old Dec 11, 2010 | 01:19 PM
95f2504x4's Avatar
95f2504x4
ya replace the fluid in it just cause its full it might not have the right amount of chemicals in it cause just like oil antifreeze breaks down over time . ford actually recommends changing the coolant every 50 to 60 k depending on driving conditions so that would be the next thing i would do
farmerwill
17
Jul 11, 2018 09:59 PM
twigsV10
1983 - 2012 Ranger & B-Series
15
Mar 4, 2016 01:56 PM
MRmundy99
Modular V8 (4.6L, 5.4L)
Jan 12, 2016 07:29 AM
rcnease
13
Nov 16, 2014 01:51 PM
lemonshindig
37
Dec 14, 2013 08:10 AM
