Aerostar Ford Aerostar
Lumbar seat pump question?
Old Dec 11, 2010 | 07:56 AM
B Dobz's Avatar
B Dobz
1996 aerostar with the seat lumbar pump under it and want to hook the rear spring lift bags line into the air pump for the lumbar seat will this work?I don`t need more then 10 lbs of air for the bags.
Old Dec 11, 2010 | 02:32 PM
xlt4wd90's Avatar
xlt4wd90
Simple way to check; hook up a pressure gauge to the pump and see how high up it will go. Even if it puts out more than 10 psi, you will be holding that button down for a really long time to pump up air springs, and you will still need some kind of one-way valve to keep the air in them. I would not rely on that tiny pump to support my suspension.
Old Dec 11, 2010 | 06:10 PM
99f350sd's Avatar
99f350sd
I have one of the pumps out and was thinking it might work for that but I have my doubts. Doesn't seem to have much ommmf..but it might. I could put a psi gauge on it for you..
Dick
Old Dec 12, 2010 | 01:00 AM
KhanTyranitar's Avatar
KhanTyranitar
I would just run the air lines where you can get to them or just by an air compressor kit. I seriously doubt the lumbar air pump can even do 10 psi.
Old Dec 12, 2010 | 01:08 AM
ford390gashog's Avatar
ford390gashog
If its like the rest of the pumps ford used they will only put out between .5 and 1 PSI as thats all thats needed.
Old Dec 12, 2010 | 10:20 AM
96_4wdr's Avatar
96_4wdr
Old Dec 13, 2010 | 06:30 PM
99f350sd's Avatar
99f350sd
2 psi is all she puts out....
Dick
RÖENTGEEP
Jul 20, 2016 08:29 PM
green_95
May 15, 2016 04:16 PM
Jefff H
6.7L Power Stroke Diesel
Jan 23, 2016 05:49 PM
abu-garcia
Ford Truck Parts for Sale
Oct 8, 2015 08:58 PM
scoobydew
Sep 14, 2006 07:57 AM
