Sponsored by: Auxito
Breather on front diff.
Old Dec 10, 2010 | 09:14 PM
bucyrus's Avatar
bucyrus
I have a 1997 F-150 4x4 with a 5.4. It has started blowing gear oil out of front differential breather tube. Enough that it has the side of the truck wet with gear oil. The oil level is app. 3/4 of a inch below the fill mark. The truck has not been in any water and the oil does not appear to have water in it. Any help would be greatly appreciated. I'm stumped to what is going on.
Old Dec 10, 2010 | 10:46 PM
steve(ill)'s Avatar
steve(ill)
the tube should not have a P trap or any type of look in it. The tube or hose should go straight up several inches above the axle and clip onto a frame member. Take the hose off and clean it out. TAke the fitting off the alxe and clean it out, or poke a wire thru it to clean--- reassemble.
