Nitrogen/Tires
Old Dec 10, 2010 | 08:53 PM
rsyauto's Avatar
rsyauto
Nitrogen/Tires
Does anyone know if the 2011 F350 SRW comes with factory filled with Nitrogen or just good old air? Thanks
Old Dec 10, 2010 | 09:09 PM
PowerStrokeHD's Avatar
PowerStrokeHD
Its just good ol air. Many will air the tires up/down depending on the load being dealt with and that just does not work well with Nitrogen...
Old Dec 10, 2010 | 10:48 PM
rickatic's Avatar
rickatic
I don't know how long just air has been used in tires...100 years...been working pretty good
Old Dec 10, 2010 | 10:50 PM
BMCM's Avatar
BMCM
I checked my tires. They are filled with about 78% nitrogen. Works real well.
Old Dec 10, 2010 | 11:45 PM
Mayne Man's Avatar
Mayne Man
how did you do that?
Old Dec 11, 2010 | 06:09 AM
Rafiki2cu's Avatar
Rafiki2cu
Nitrogen is done by dealer. Nitrogen will improve your ride and also make your tires last longer. I owned a small trucking company and nitrogen really helped on the tires wearing out. I only lose about a pound of air pressure every six months with nitrogen.
Old Dec 11, 2010 | 06:21 AM
Adobe 11SD's Avatar
Adobe 11SD
I suspect BMVM was making a funny. The air we breath (and put in our tires) is 78% nitrogen and 22% oxygen.
Old Dec 11, 2010 | 07:56 AM
rickatic's Avatar
rickatic
exactly...
Old Dec 11, 2010 | 12:35 PM
Tom's Avatar
Tom
I disagree with this. How exactly is nitrogen supposed to improve the ride?
The only way it will help with tires wearing out is by leaking out a little bit slower, which can be rectified by simply checking tire pressures once a month.
Old Dec 11, 2010 | 05:14 PM
Rafiki2cu's Avatar
Rafiki2cu
Yeah I know it sounds crazy but I ran nitrogen in all my company trucks and my car/and rv. Check out Nitrofill.com for info.
Old Dec 11, 2010 | 05:30 PM
rickf92592's Avatar
rickf92592
There are only two advantages to Nitrogen in tires; Nitrogen tends to be drier (won't absorb/carry H2O which makes pressures more stable as temperatures rise) and Nitrogen molecules are larger so they don't permeate the tires (leak-down) as quick.
Putting a dryer on your compressed air supply works very, very much the same.
As it was said, we already are operating on 78% Nitrogen.
BTW, Nitrogen does absolutely nothing to improve your ride, all things (pressure) being equal.
Your tires are springs and the higher the pressure, the firmer the spring.
