P1335 Code
Old Dec 10, 2010 | 05:49 PM
i eat hybrids's Avatar
i eat hybrids
P1335 Code
My check engine light came on today and the code read P1335. What code is that?
Old Dec 10, 2010 | 07:36 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
P1335 = EGR position sensor minimum/maximum stop performance. Could be the valve is dirty. You might want to pull it out and have a look.
There's a good thread on removal/cleaning of the EGR valve in the 6.0 tech folder sticky.
Old Dec 13, 2010 | 12:54 PM
i eat hybrids
Thanks! Would it hurt to keep runnin the truck like that? I know i had the EGR replaced 5 months ago under warrenty
Old Dec 15, 2010 | 11:13 AM
i eat hybrids
bump... bump...
Old Dec 15, 2010 | 08:57 PM
cheezit's Avatar
cheezit
p0405 may disable the cooling fan.
Old Dec 15, 2010 | 09:08 PM
vlietracer64's Avatar
vlietracer64
Not to hijack the tread but cheezit, in another thread we talked about how removing the egr valve can have a direct effect on fan operation. Now we all know with these motor they raise combustion temps to help reduce emissions. Could the ECM actually be programmed to delay fan functions to create higher heat in engine to help reduce emissions when the egr system has been compromised. Seems like a gamble to run engine hotter but hey you never know. I know you have ran a few test and seen lower fan rpm's when egr system is non-operational. Is there a limit when the fan will kick in to keep the motor from melt down?
Old Dec 15, 2010 | 09:10 PM
bismic's Avatar
bismic
The recirculation of exhaust gas is to lower the flame (or combustion) temp. That reduces NOx emissions.
Old Dec 15, 2010 | 09:12 PM
cheezit's Avatar
cheezit
emmm. egr is there to reduce Nox. Nox is formed at 1500*f. we want to add exhaust gas to reduce cyclinder temp.
I belive the the circuit that is effected is circuit 351 and for some reason it ties in to actavating the fan. I satill havnt figured out why they are doing this but they are. I do need to send a contact threw and ask if anyone has a clue
Old Dec 15, 2010 | 09:17 PM
vlietracer64
Sorry for the mstake, for some reason i thought i recalled something about rasing combustion temps to reduce NOx.
[COLOR=black][FONT=Verdana] My mistake, thanks, still would like to find the correlation between the egr and fan circuit
Old Dec 15, 2010 | 09:20 PM
cheezit's Avatar
cheezit
like I said its hooked threw cicuit 361. I belive the last 2 legs of that circuit is the egr valve then the fan clutch.
but that still has me wondering why the maf and the gpcm dont have that issue if that was the real cause.
Old Dec 15, 2010 | 09:47 PM
Ford_Doctor's Avatar
Ford_Doctor
If your EGR valve was replaced 5 months ago and it has a minimum stop performance issue it is either loading up heavily or has a carbon chunk stuck in it. It is very common to find a bad EGR cooler causing low mileage repeat EGR valve concerns like sticking or hanging open.
Old Dec 16, 2010 | 05:04 PM
i eat hybrids
Ok, thanks! that was the answer i was wanting/not wanting lol But i have a warrenty so its all good. What would happen if i kept driving the truck? Since i dont have guages, i cant really tell ya the EOT and ECT temps.
And cheezit, my rig wasnt pullin those codes.
Old Dec 16, 2010 | 05:52 PM
Ford_Doctor
At this point monitoring the temps isn't going to help other than diagnose a cooler problem. Yeah, you can drive the truck but you will likely experience driveability issues and if the valve hangs open enough the engine will smoke, stall and even not start. The longer you drive it without addressing this problem the more likely you are to have a problem... usually at an inconvenient time!
Old Dec 16, 2010 | 11:24 PM
i eat hybrids
Sounds like i may have a EGR delete on order soon haha Thanks for the response!
Old May 20, 2017 | 10:15 PM
pvanzan's Avatar
pvanzan
I had a P0404 and a P1335 and had no turbo boost, but idled fine. Took out EGR found a chunk of carbon stuck in the valve cleaned it up, and it ran like champ afterwards.
RobbieR
6.4L Power Stroke Diesel
Feb 1, 2018 06:38 AM
mrgrayaz
Oct 17, 2017 05:15 PM
4Snow
Jan 13, 2017 09:26 AM
alxhockey
Jun 21, 2016 11:30 PM
jereli
Mar 21, 2016 10:34 PM
