Alignment issue...
Old Dec 12, 2010 | 08:07 PM
  #31
tbone heller's Avatar
tbone heller
If your truck drove good before you changed the wheels & tires, I would say that the wheels & tires are causing your "pull". What load range tires are required for your truck? What load range tires did they sell you? I would bet that your new tires are a light-duty tire that cannot run the factory recommended tire pressures for you truck. I have run into this hundreds of times as the alignment guy at the Ford dealer.
Old Dec 13, 2010 | 05:55 AM
  #32
Michael250's Avatar
Michael250
The tires I had on were "E" (10 ply), and the ones I put on were "D" (8ply). One more thing I just thought of...with the new tires they would rub just slightly against the bumper. I eventually just ground off the bumper corner a bit, but before I did that I tried to pry the bumper forward by putting a jack between the bumper and the front axle. That couldn't have done anything, could it??
Old Dec 13, 2010 | 10:59 AM
  #33
Copedawg's Avatar
Copedawg
The signature looks good!
What I did was was remove the bumper and and replaced the bolts with longer ones and threw a bunch of washers on it to shim it out.
Old Dec 13, 2010 | 12:39 PM
  #34
Michael250's Avatar
Michael250
Hey Copedawg - that would have been a good idea. Oh well, as I said I just ground down the edges of the bumper and it worked. You can't even notice unless you get under the truck. hey, BTW, thanks for the advice on the signature!
Old Dec 13, 2010 | 11:05 PM
  #35
Dave Sponaugle's Avatar
Dave Sponaugle
That depends on how much pressure the jack had on the front axle and exactly where it was located.
Old Dec 14, 2010 | 05:59 PM
  #36
Michael250's Avatar
Michael250
Originally Posted by fishmanndotcom
funny this should come up, couple of weeks ago while trying to find the source of a noise i found the centerpin on the front driver side leaf pack was gone! when i took the pack apart there was just a small nub left in the spring pad not doing anything! glad i found it before something bad happened!
this is a pic of my bronco but i am running a sterling so it is exactly the same. the center pin is, well, in the center of the plate
-cutts-
fishmanndotcom and RRranch, thanks for the advice. Haven't had a chance to check it yet (had 7,000 mile an hour wind here recently, and I have to do all my work outside ). I'm putting in my new gp's tomorrow, so I hope to check it out then.
Old Dec 14, 2010 | 06:04 PM
  #37
Michael250's Avatar
Michael250
Dave I had the jack wedged betwen the left corner of the bumper and right by the rotor. I'm wondering, though, because all that happened is that the bumper would bend forward, and then when I removed the jack it would just spring back to it's original position.
Old Dec 14, 2010 | 06:10 PM
  #38
RRranch's Avatar
RRranch
I was just wondering. YOu said you got d tires on it now. Are the max inflation pressures on the sidewall 80 psi? If they are 50 then they can cause this.
And if they do say 50 then you need to go back to that store and demand the proper tires be put on your truck. Federal law requires them to put tires rated at or better than what your door sticker calls for. And I know it calls for 80 psi rear.
Old Dec 15, 2010 | 10:34 AM
  #39
Michael250's Avatar
Michael250
Hey RR - the tires are rated at 65 max. I know I should have gotten "E" rated tires, but I had a hard time trying to find tires that were good and didn't cost a fortune. I ordered the rims off ebay and the tires I ordered from a guy on the mainland, so there is no one I can go back to. if this is the case, then it's totally my fault...
Old Dec 15, 2010 | 11:07 PM
  #40
Dave Sponaugle
And if you look at the weight rating, most likely the 285 D rated tires will have a higher weight rating than the 235 E tires.
Cooper Discoverer S/T
235/85-16 Load range E, 80 PSI max inflation, 3042 pounds max weight
285/75-16 Load range D, 65 PSI max inflation, 3300 pounds max weight
265/75-16 Load range E, 80 PSI max inflation, 3415 pounds max weight
