hi i have a 1995 f 150 flareside 5.8 v8 it idles good in park and does not hesitate when accelatring ,however it will stall in drive and reverse and at red lights seems like at low rpms any ideas? thanks to all
you can also check the resistance with your multi meter the resistance should be between 7 and 13 ohm's. i just replaced mine only had 5.3 ohm's of resistance.
sorry for the delay i caught up in the holidays! ok i changed the iac, rotor and cap no difference got the transmission fluid and filter changed and have not had a problem since been about 3 weeks now runs great thanks for everyones help !
