P0237 no boost code
Old Dec 9, 2010 | 09:46 AM
baredog26's Avatar
baredog26
Angry P0237 no boost code
I have a 99 F550 with the 7.3 that won't get above 45mph and is throwing a low boost code. The turbo only has 6,000 miles on it, but i took it off and checked it out. Everything looks good. I can't hear any leaks, and I checked all 6 rubber boots everything looks good. With my scan tool hooked up i drove it around and with the pedal to the floor the most my IPR would show was 42%. Could that be my problem? I appreciate any help or suggestions.
Old Dec 9, 2010 | 10:35 AM
PaysonPSD's Avatar
PaysonPSD
Check the small black hose from the bottom of the spider to the MAP (Manifold Absolute Pressure) sensor. If that hose is off the MAP can't read boost. If the MAP sensor is good the scanner should be able to read ambient baro pressure with just the key on. If it doesn't the MAP sensor is bad or there is a connector or wiring problem. At sea level it should read about 14.7 PSI. I don't know if the PCM will go into a limp mode for lack of boost but that might be why you are limited to 45 MPH.
Old Dec 9, 2010 | 11:07 AM
Izzy351's Avatar
Izzy351
I doubt is a sensor issue -- I forgot to plug in my boost sensor and it drove fine, but threw a code (same one, I believe). Sounds like you actually have no boost. This is where a real, separate boost gauge pays off.
Any other symptoms besides won't go over 45 mph? What did you read the codes with? IPR is perfect for stock tuning. I assume if you look at the boost reading from the PCM is shows nothing, right? When I read the MAP mine shows real boost numbers, not baro -- the backpressure sensor shows baro however...
Old Dec 9, 2010 | 11:30 AM
PaysonPSD's Avatar
PaysonPSD
There are 2 readings you can look at, at least with AE. Absolute and guage pressure. Gauge pressure is minus baro. Absolute is baro plus boost. Both readings come from the MAP. Yes, the EBP sensor will also read baro with KOEO.
vtsjr
Dec 5, 2025 09:48 AM
busabuggy
Jan 1, 2019 09:32 PM
Chief Many Inches
20
May 6, 2017 09:49 PM
jokerj280
Dec 25, 2016 07:59 PM
riggermortis
Aug 11, 2015 04:16 PM
