Manual choke problem
Old Dec 8, 2010 | 08:04 PM
bkohne1's Avatar
bkohne1
I have a 77 f250 w/ 351m and a manual choke setup. (installed when i bought truck) When i try to start the truck the choke does not do anything except kill the motor... I have to feather the gas for awhile till it warms up. Isnt the choke suppose to put it into a higher idle so it will warm itself up?
Old Dec 8, 2010 | 10:35 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Usually you pull the choke closed, hit the start and push the choke in a little as the engine cathes.
And yes, more often than not you may have to feather the throttle initially to help "burp" the engine, but after 10-15 seconds it should be idling fairly well.
Also, you should notie that as the engine warms up you will need to puch the choke in to keep the revs down.
Josh
