5th Wheel Hitches, options?
Old Dec 11, 2010 | 07:06 PM
  #46
EpicCowlick's Avatar
EpicCowlick
Deere, You're absolutely right. I didn't have the pin in place when I tightened down the torque bolt. It pulled all the way to the top of the base plate and of course put no pressure on the side pin. I then released the side pin into the lower hole which the instructions say not to use. I must admit that I did not actually read the instructions. My helper was doing that. Thanks for covering my rear end for me.
Old Dec 11, 2010 | 07:17 PM
  #47
720Deere's Avatar
720Deere
Well I guess we will call it even because I didn't know there was a spacer kit for the 2011 until your installation made me check their website to make sure I wasn't crazy. When I was looking up the installation instructions for the Companion, I stumbled upon the spacer/pad feet kit as well. Now if I could only find somebody that actually sells the darned thing.
Old Dec 11, 2010 | 08:43 PM
  #48
porthole's Avatar
porthole
How much weight is being transferred to the bed of the truck?
Old Dec 11, 2010 | 08:54 PM
  #49
rickatic's Avatar
rickatic
Although I am unsure of what you mean, the weight transferred to the box is equal to the pin weight of your fifth wheel. I have a Duraliner in my truck bed. The center hole for the turnover receiver is removed. The bed liner is also notched for the safety chain loops. I drop my hitch into the center receiver, release the locking pin, torque the tension bolt to 40 ft pounds and then the u bolts to 80 ft pounds. Hook up the fifth wheel and hit the road. 10000 miles on 2 different trucks with no problems.
Regards
Old Dec 11, 2010 | 08:58 PM
  #50
EpicCowlick
I think Porthole is asking how much weight the actual bed is bearing. The B&W hitch (and all hitches for that matter) are designed to transfer the weight of the trailer through the bed to the cross-members underneath the bed and onto the frame. The bed itself doesn't carry much load. It cannot because it is simply thin steel.
I don't know how much is on the actual bed, but there is theoretically some. It just can't be very much.
Old Dec 11, 2010 | 09:00 PM
  #51
porthole's Avatar
porthole
What I mean: if pin weight is 2500 pounds, how much of the 2500 is directly placed on the frame and how much gets transferred to the outside edges/pads of the hitch body, where it rests on the corrugated sheet metal?
The hitch is being pulled down against the bed of the truck, right? So there must be some transfer of weight to the bed/body.
Old Dec 11, 2010 | 10:32 PM
  #52
rickatic's Avatar
rickatic
I understand the question now. As I said earlier, my Companion sits on top of my bed liner. There is little to no compression damage done to my bed liner that I can see after removing my hitch. This would indicate that the big feet of the Companion spread the load quite a bit across the bed. I was considering using a Sidewinder pin box for the trailer we almost bought before the Big Horn. B&W does not recommend, in fact they have published a disclaimer, using a Sidewinder pin box with a Companion hitch. The wedge that locks the hitch at the kingpin evidently puts too much twisting force on the mast. Sidewinder does make a wedge for the Companion but they require you to drill a hole through each of the feet and through the box to eliminate this twisting. B&W must be happy with the small twisting force that just the king pin generates working against the resistance of the feet and the torsional strength of the mast. Did that make sense...It's late
Old Dec 12, 2010 | 01:17 AM
  #53
Mayne Man's Avatar
Mayne Man
Originally Posted by Reagansd350
What did the reese hitch cost you? I just picked up my truck and need to get the hitch, just wondering if they are dealing on them?
I am in B.C. Canada. I got the hitch for 1030 cdn.$ Through a guy I know who has a hitch shop. I see them on tweetys for 1130 us$ with free shipping and probably no tax.
Old Dec 12, 2010 | 08:00 AM
  #54
720Deere's Avatar
720Deere
My answer would be all of the pin weight is transferred to the bed and any pulling force required to drag the trailer is handled by the gooseneck hitch. Since these trucks are rated to haul 3500+ lbs placed directly in the bed, I don't see it being a problem.
Old Dec 13, 2010 | 01:01 AM
  #55
sncbluegt's Avatar
sncbluegt
I have been wrong before but I don't think any weight is actually transfered to the sheetmetal of the bed...BECAUSE I think the companion sits directly on the bed bolts that directly bolt to the frame...direct transfer of weight to the frame.
Old Dec 15, 2010 | 11:13 PM
  #56
Johnnyturbo's Avatar
Johnnyturbo
I am in the market for a new hitch in my 2011 f350 6.7 KR CC short box. I am also from BC Canada on Vancouver island and wonder, if I may ask, is this the under mount system or rails above in the box? I am just starting to look at options and after having the above bed rails for the last 7 or so years would like to see how optional system looks. Any info would be greatly appreciated.
John
Old Dec 16, 2010 | 12:29 AM
  #57
sncbluegt's Avatar
sncbluegt
John
If you look at the pictures of the installed B&W companion hitch on page 3 of this thread that will give you a great real picture of what it looks like. When you don't need the fifth wheel just loosen a few bolt pull the lever and pull it all out and you now have a smooth bed.
Old Dec 16, 2010 | 01:08 AM
  #58
Mayne Man's Avatar
Mayne Man
John
Hj John, I am on Mayne island. I have the 5th wheel prep package from ford that is mounted under the box.It looks like a really neat set up. I don`t know what you have to do to put it in the short box. they tell me I would have to get a different set up if I had short box.I havn`t towed with it yet. I leave for south on next Wed. so we will see how it works. Any Questions I would be happy to answer if I could.
Old Dec 16, 2010 | 10:47 AM
  #59
EpicCowlick
This is what I ended up hooking onto the B&W hitch. Now I just have to find my 5er feet. This beast is LONG!
Old Dec 16, 2010 | 12:17 PM
  #60
rickatic's Avatar
rickatic
I am honored to make my 2000th post here a compliment to my good buddy Epic... Great looking rig. It is long...and it will turn well inside the truck around the corners. Have you had a chance to weigh the rig? It sits about the same as my 13000 pound Big Horn with 2450 pounds of pin weight. Looks like an early Epic...Christmas in SLC
Merry Christmas
