9" question
Old Dec 8, 2010 | 10:18 AM
Greyf100's Avatar
Greyf100
9" question
I have an '81 F100 with the Small BP 9" (5 on 4.5"), after doing some thinking (very dangerous) could i bolt Exploer rear disc brakes on my axle tubes without modification? The calipers are held with the backing plates which bolt to the axle housing. and i could use the discs from the explorer also, same bolt pattern. I guess what i really need to know is, are the 8.8 flange bolt pattern and the small pattern 9" flange the same bolt pattern?
Old Dec 8, 2010 | 11:36 AM
82F100SWB's Avatar
82F100SWB
This is something you'll have to investigate. I know the 5x5.5 9" and 8.8 of this era share the same bolt pattern and backing plate for the drums, no clue on the Explorer stuff though.
Old Dec 8, 2010 | 05:22 PM
Greyf100's Avatar
Greyf100
i looked when i got home it looks like the flange is the same as the big bearing 9", I found a website with a pic of both.
Old Dec 8, 2010 | 10:39 PM
bob_351's Avatar
bob_351
google! there is a ton of info about this. infact ford (or somebody) sells this as a conversion kit using stock exploder parts. and from what i read a lot of it has to do with if its a big bearing rear end or not
Pearlwhite94
Apr 21, 2008 10:37 PM
Dave Severson
Aug 3, 2006 03:59 PM
create
May 2, 2006 06:26 AM
house
Aug 28, 2003 01:02 AM
slammerz
May 18, 2000 09:19 AM
