intermittent lost power
Old Dec 7, 2010 | 11:09 PM
jrod16's Avatar
jrod16
Just finished a complete front end rebuild, hubs, ujoints, axle seals, ball joints, ect. Truck was sitting for about 5 weeks with just under a 1/4 tank of fuel. threw some diesel kleen and 100% petroleum fuel in. left to go to work and headed up hill the truck was bogging down with a check engine light on. about 10 miles down the road problem stopped and light went off. when i got home from work i changed the fuel filter. today left for work and same problem engine bogging down like it was running out of fuel. the problem stopped after about 10 miles. the truck drove fine both days on the way home. Any suggestions? btw 2002 7.3L auto
Old Dec 8, 2010 | 02:13 AM
Sheldon Plankton's Avatar
Sheldon Plankton
Have you pulled the codes?
It could be a lot of things, but this is exactly what my truck did when my OEM CPS was starting to check out.
My $0.02.
Old Dec 8, 2010 | 11:15 AM
clintbonnie's Avatar
clintbonnie
I agree, pull the codes.. It will tell you where the problem is..
Old Dec 8, 2010 | 06:59 PM
jrod16's Avatar
jrod16
can you still pull codes even though light is not on? i believe the cps was changed before i bought the truck but i will check again. i cleaned the ebvp hose and sensor as well, no fix. also it has been an average of about 15 degrees here in illinois dont know if that makes a difference.
Old Dec 8, 2010 | 07:40 PM
clintbonnie
Yes, you can pull the codes with the light on..but.. not all scanners will work on our 7.3l.. FYI
saxtonj
17
Jul 15, 2013 08:51 AM
Wynn93
Nov 7, 2012 08:22 AM
rbarrette
Jun 20, 2012 12:32 PM
SISKO-KID
Feb 9, 2011 09:16 AM
Stinky 60 F100
Nov 3, 2003 12:00 PM
