no brake lights
Old Dec 7, 2010 | 10:55 PM
brknight's Avatar
brknight
no brake lights
no brake lights. have replaced the fuse and brake switch still not working. not sure what is next any help is greatly welcomed,thx
Old Dec 7, 2010 | 11:02 PM
78 PEB's Avatar
78 PEB
Have you checked at the switch to see if you have power going in.............then step on the pedal and see if you have power coming out.......also make sure the switch is properly adjusted so that it works when you step on the brake pedal.
Old Dec 8, 2010 | 07:40 AM
Justin's Green Truck's Avatar
Also check the turn signal switch behind the steering wheel in the column. My brake lights went out and this turned out to be the culprit. Find you a wiring diagram and a multi-meter and check it out. Took me forever to realize thats what it was. The way i found it was I noticed if i hold the brake pedal down and jiggle the turn signal stalk, the brake lights would flicker. This is with the key off.
Replaced the switch and that fixed it. A repair manual will have wiring diagrams or you can go to auto zone online repair manual.
Hope this helps
Old Dec 8, 2010 | 07:55 AM
BoomerTexas70's's Avatar
BoomerTexas70's
When i first bought my truck I had a problem with my taillights/brakelights would flash...? And when i hit my turn signal they would work properly till the wheel was turned back releasing the turn signal. Someone had removed the bed and just cut the wires, when they were butt connected back together the wires were switched around. So becareful of that or if you have a bad ground could cause your brakelights to be on permanently, appearing that they dont work.
Old Dec 9, 2010 | 09:56 PM
hp246's Avatar
hp246
You don't mention whether this is a styleside or flareside. One possibility is a ground or broken wire. Especially on a flareside. The wires were somewhat exposed. Are you sure you have the right bulbs? It is possible (hard, but possible) to get a side marker bulb in the bulb holder by mistake, but it is missing a filament, so you will lose a function on the bulb.
Before I started dismantling things, I'd take a look underneath, make sure there are no broken wires. Check all your grounds and make sure you have good clean grounds.
Old Feb 20, 2011 | 06:36 PM
brknight's Avatar
brknight
turned out to be the little itty bitty fuse was not the right one,ugg
Old Feb 21, 2011 | 07:50 AM
Glad you fixed it
