1978 - 1996 Big Bronco
no 1st
Old Dec 7, 2010 | 10:24 PM
murph_murphy's Avatar
murph_murphy
no 1st
Hey if anyone has any information on this could you help me out:my bronco it has the PARK,REVERSE,NEUTRAL,DRIVE,2,1 (like the rest) but on mine i cant seem to get it into 1st could it be because, there is a new steering wheel column or something along those lines????? no idea so any help would be great thanks,
murph
Old Dec 7, 2010 | 10:57 PM
g_k50's Avatar
g_k50
Might be the indicatior is out of adjustment and you actually have 1's but it's not showing on the indicator because it's out of adjustment. This haplpened to me on my 1999 Ranger and the fix was to buy a new 30 dollar indicator eventho the part that was broken was a 2 cent screwblock.
Old Dec 8, 2010 | 10:54 AM
b4hntn's Avatar
b4hntn
Haynes manual tells how to adjust cable at the MLPS on driver's side of transmission. If that does not cure it I would suggest cleaning four connectors as mentioned in another thread. It only takes one corroded pin for a solenoid not shifting correctly.
Old Dec 8, 2010 | 04:11 PM
murph_murphy
the shift lever is kind of wobbly and it does not engage into first, i can't actually feel it go into 1st. its as if something is blocking the shift lever from going all the way over into 1st. just thought that maybe that would be a tad bit more help. i guess it could use that adjustment your talking about. i just want to try everything that is free before i need to buy something. also when it is in drive or reverse or anything the shift lever is really loose i can put the little red arrow indicator over 2nd and still be in drive.
Old Dec 8, 2010 | 05:29 PM
greystreak92's Avatar
greystreak92
At the base of the column (right above the driver's shins) there are a couple of small bolts that secure the shift linkage down to the trans. These are known to work loose on the late model trucks and Broncos. Tighten them up and you should lose the "wobble" in the shift lever and will probably discover that 1is is still there and usable once everything is tightened up again.
Old Dec 8, 2010 | 06:10 PM
murph_murphy
alright ill go give that a shot and see how it all turns out thanks.
Old Dec 8, 2010 | 06:27 PM
murph_murphy
alright for the life of me i could not find these bolts do i have to take the covers off of the dash or something like that or are they visible from just looking under the steering wheel?
Old Dec 9, 2010 | 06:02 AM
b4hntn's Avatar
b4hntn
Way down low and on top of the assembly. They are kinda hard to see. Get your head near the pedal. Digital cameras are great to help see.
Old Dec 9, 2010 | 04:19 PM
murph_murphy
thanks i will give that a shot and see if i am able to find it.
hey just want to say thanks to everyone who has helped me on any questions when i first saw this website i thought it was great and decided to join.
Old Dec 9, 2010 | 05:02 PM
murph_murphy
hey it worked and now i don't have to be riding my brakes down every hill haha thanks again also i checked it in 4lo and a lot slower than what i had before yea both the screws were fairly loose the top one not quite as much as the bottom one i was also fiddling around with the indicator mover ***(no idea what it is called) but anyways the fact is that it works now
murph77
Jul 28, 2009 07:37 PM
murph77
Illinois Chapter
23
Jun 17, 2009 10:20 PM
murph77
Apr 27, 2009 12:54 PM
murph77
Aftermarket Products
Jan 31, 2009 03:51 PM
odinmurphy
Nov 30, 2000 12:12 PM
