Sponsored by: Real Truck
EGR System Malfunction
Old Dec 7, 2010 | 11:37 AM
SOB Racing's Avatar
SOB Racing
6.0 diesel motor- Recently I have had a tone change coming out of the exhaust. The truck usually has a hissing turbo sound. Sometimes it changes to a sound of a gas motor then reverts back and forth. I have traced it to the EGR system. I have been running the truck with the EGR electric motor unplugged and the sound is back to normal and the truck runs great. I think the EGR system is dirty and clogged. What method and what parts need to be removed to clean the system. Also what would be used to clean the parts.
Old Dec 7, 2010 | 11:46 AM
npccpartsman's Avatar
npccpartsman
Lots of information in the 6.0 diesel forum on this.
The turbo changing tones can be from the EGR but there's also a computer strategy that cycles the turbo vanes to help keep them from sticking due to carbon.
To clean the EGR valve you need a 10mm socket and a lady's foot crowbar OR a length of wire and a long prybar to get it out. You'll also need to pick up some EGR valve o-rings. Use CARB CLEANER (not brake cleaner) to clean the EGR valve with. Clean it in an UPRIGHT position so that the cleaner doesn't get into the weep holes and ruin the electronics of the vave. Replace the o-rings and reinstall.
Old Dec 7, 2010 | 12:06 PM
SOB Racing's Avatar
SOB Racing
Is the valve and electric motor one part.
Old Dec 7, 2010 | 12:41 PM
rocky1074's Avatar
rocky1074
Egr Valve is all one unit. The EGR Seal Kit Gasket and o-rings part number <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->3C3Z-9P455-AB about 6-7 bucks
Old Dec 7, 2010 | 12:49 PM
SOB Racing's Avatar
SOB Racing
Exactly what i needed. Thank you!
Old Dec 7, 2010 | 12:59 PM
rocky1074's Avatar
rocky1074
That's just the seal kit...NOT THE VALVE!!!
melissar
Escape & Escape Hybrid
15
Jul 13, 2019 05:07 PM
2006powerstroke90
Apr 1, 2017 09:54 PM
Targa185
Feb 10, 2015 02:04 AM
Thorntontribe
Nov 23, 2014 03:30 AM
mse871859949
Jun 15, 2014 11:52 PM
