Hello All, It's been awhile since I last posted, anyways I have a 79' F150 4x4, and the front suspension is very bad, shock mount broke off on radius arm, springs held on by hose clamps and C-bushing that are deteriorating.
I am looking for a set of aftermarket radius arms but can't seem to find a company that makes them. I know Cage Off road did but there no longer available and I did find a set for fullsize Bronco's at JamesDuff.com Does any one know if these would fit or have other suggestions.
Thanks
I would find some stock arms in a junkyard and make your own extended arms. You can lengthen them as long as you want, and it will most likely be cheaper than any that are still available. I don't recall any 73-79 arms being available anymore.
