motor problems
Old Mar 2, 2003 | 03:41 PM
skycarpslayer's Avatar
skycarpslayer
motor problems
I have a 1986 F-150 w/a 5.0 Fuel Injected Motor. About a week ago it started to die at random. It then started to happen more frequently. When it would die, after sitting for about ten minutes it would start back up. I changed the high pressure fuel pump and that fixed the problem for about two days. Then it started again so i changed the coil. That didnt help so i move to the pickup in the distributor. Still nothing, won't even start. Will turn over but wont start. Any suggestions?
Old Mar 2, 2003 | 06:39 PM
ecarter50's Avatar
ecarter50
motor problems
fuel pump relay?
Old Mar 2, 2003 | 10:47 PM
steve83's Avatar
steve83
motor problems
Get a Haynes manual (or you might find the info here) and diagnose the ignition system. It's likely the ignition module, which is mounted to the distributor.
