High RPMS
Old Mar 2, 2003 | 01:14 PM
little truck's Avatar
little truck
Angry High RPMS
Gentlemen
I have a 1994 Ranger XLT with a 2.3L engine with a 5 speed manual overdrive transmission. I bought this truck 6 months ago and when I got it, in between shifts the engine rpms would not drop off. Now the problem is getting worse! When I drive down the street the trucks goes 30 miles per hour without my foot on the gas pedal. Once the truck warms up sometimes the rpms drops down to were it should be. But at other times it does not. I would apprecate any help.
Thanks Jim
Old Mar 2, 2003 | 11:14 PM
jonpe58's Avatar
jonpe58
High RPMS
sounds like the throttle cable is out of adjustment or bent or binding on something. check the throttle cable where is is connected to the fuel injector bore where the hose from the air filter is connected to the fuel injector bore (looks like a carb.).
the cable may also be stuck on something. It should be fixable without a lot of money involved.
Old Mar 3, 2003 | 08:59 AM
Ken00's Avatar
Ken00
High RPMS
Welcome to Ford truck enthusiast!!
It could also be a sticking IAC, also check for TSBs on this topic I recall some years having one. See the link on the rght side.
Old Mar 3, 2003 | 01:08 PM
Charnsen's Avatar
Charnsen
High RPMS
I had a similar problem earlier this winter on my '92 4.0L. When putting the truck in drive or neutral, the engine would race to ~3000 RPM and when in gear would cruise down the road all by itself. A recently replaced (and mis-adjusted) Throttle Position Sensor (TPS) was the culprit. Reset it to 0.90 VDC and things have been fine since.
Old Mar 4, 2003 | 05:56 PM
little truck
Talking High RPMS
Gentlemen
Thank you for all your help with the high rpm problem. The problem is now resolved. I replaced a bad Throttle Position sensor (TPS) and also a bad IAC solinoid.
It goes to show you that fellow truck people like to help each other out!
Thank you again
Little Truck
Jim Rozycki
Old Mar 5, 2003 | 02:11 AM
DainBramage's Avatar
DainBramage
High RPMS
Nevermind, question's been answered. Should have read the whole thread...
49f2owner
Apr 13, 2012 01:45 PM
KoolAidMan888
Nov 28, 2010 09:08 PM
guthrie&co
Mar 1, 2009 10:07 AM
V8EXPLR
2004 - 2008 F150
19
Jun 12, 2008 10:49 AM
ferchja
1997 - 2003 F150
Apr 19, 2005 12:53 PM
