trans temp gauge
Old Dec 4, 2010 | 09:17 PM
bc18's Avatar
bc18
trans temp gauge
i just got an autometer trans temp gauge and i want to hook it up to my truck. i have a 1995 ford f150 e405 trans and 5.8l 2wd. has anyone hooked one of these gauges up to their trucks and if so how.
Old Dec 5, 2010 | 12:51 PM
bc18's Avatar
bc18
anyone know?
Old Dec 5, 2010 | 01:02 PM
lew52's Avatar
lew52
Tap into the side of the trans pan , i use an autometer on mine but with a alum pan , you might need to weld a bung on the stock pan , should come with the gauge...Lew
Old Dec 5, 2010 | 01:31 PM
danr1's Avatar
danr1
Yea I added one to my plow truck, I didn't want the sending unit down under the truck.
Plowing snow its not uncommon to drive through/over deep piles of heavy snow while doing so, because of that I put the sending unit behind the grill instead, inline at the inlet side of the first fluid cooler.
My inferred gun and gauge both agree with each other so I know its close enough.
The pan yea likely the best spot, in the pressure tap just above it is also a suggested location.
Old Dec 5, 2010 | 11:09 PM
86F150302's Avatar
86F150302
Yes I do in my E4OD. No need to drill or tap anything.
Here is where to put it.
Old Dec 6, 2010 | 02:09 AM
hav24wheel's Avatar
hav24wheel
That's where I had mine when I had a E4OD.
Old Dec 6, 2010 | 05:09 AM
lew52's Avatar
lew52
Never had an E40D...
wicat3
Nov 9, 2012 10:31 PM
Shooter00
13
Dec 23, 2011 08:29 PM
AuerF250
Apr 7, 2011 03:31 PM
carrfamilynj
Jun 23, 2007 07:16 AM
wldcat65
Mar 8, 2006 07:21 AM
