Good afternoon folks.I'm in the process of flushing my old coolant,in preperation for a new water pump and ELC,and I have a question about Gooch's procedure.I can't for the life of me get the pass side engine drain plug to budge,if I remove the starter,sure no problem,but I really don't want to R&R that thing 2 or 3 times.I have clear water(distilled)flushing from rad and driver side plug.Am I ok to not remove pass side to drain?
Thanks.
Without using the universal swivel, I found I couldn't get the tool to seat properly which kept me from getting a good enough torque on the plug.
Also, I know Gooch suggests removing the passenger side plug without using an extension, but I used one, with a wobble on the end. It can be a little tricky, but it worked well for me.
Has anyone used the old Prestone flush and fill kit?? I used to use them on older Ford gassers of mine and thought they did a pretty good job of flushing everything out.
Update.I tried the swivel and an extension to get the pass side plug out,no budge at all,so I just flushed one more time.Put on new water pump,tstat and housing,upper and lower rad hoses,belt,degas bottle and Prestone HD ELC.Everything went pretty smoothly with instructions from FTE.I did have 2 issues.1-Autozone and Oriellys didn't have the tool to hold the fan pulley.Autozone wanted to sell me a 3 jaw puller to get the fan off,I smiled and said no thanks.Napa doesn't rent tools anymore,but they had the set for sale 75.00,and if I would have bought it sunday,they would have given me 15.00 off.I couldn't justify spending that for a one time deal.What I wound up doing is using a rubber strap wrench to hold the pulley with one hand,the 1 7/8 wrench with the other while my wife tapped the wrench with a dead blow,came right off.All in all not a bad job.
The local NAPA sold me just the universal pulley tool for $25, so I did that. the ones in the rental kits were worthless. The real trick was the air chisel I bought from harbor Freight for $15-20. I had the fan off in seconds.
Thanks.
That pass side was quite a bear for me when I did the flush this summer. I finally got it though. Once you figure out the method it was super easy to do. I would think that even though you didn't get it out you should be good on your flush.
