4x4 Clunks & binding?
Old Dec 6, 2010 | 09:27 PM
wyckedcombo17's Avatar
wyckedcombo17
Thanks for the tips! Is to the spindle the farthest in I need to take it apart or do I also have to take off the knuckle too?
And did anything require a torch?
Old Dec 6, 2010 | 09:56 PM
dave_dj1's Avatar
dave_dj1
the knuckle can stay, be careful when sliding the axle shafts in or out, that you don't wreck the inner seal. It's also VERY important for the life of the wheel bearings to take your time and get them torqued properly. The two large nuts and the spacer between them is a PIA but with some patients you can get it just right. Look for an exploded view, there are dust/debris seals and plastic spacers that go just on the inner side of the inner wheel bearing, without these installed properly (if they are indeed still there) crud and crap can get in the back of the hub and shorten your bearing life.
One other thing to keep in mind is that the spindle bolt patterns are not equal, they have to be clocked a certain way. It's kind of self explanatory once you get to it.
Old Dec 6, 2010 | 10:28 PM
wyckedcombo17
Okay, thank you very much! That is very helpful! Hopefully I can find a diagram from Mi1lion or steponit will see this...
Old Dec 11, 2010 | 11:55 PM
wyckedcombo17
So I was talking to my dad tonight and he said when he's done U-Joints he doesn't unbolt anything, just pops the caps off.
Does his logic apply to the axle shafts? I realize that theres a way to do things so that you don't have to take much else apart, like say just dropping the pan to put a new crank in but that makes all the other aspects of the work to be done hard. Can I just pop off the caps or is removing the wheel / hub / spindle and then sliding out the axle shaft the "easy" way to do this?
Old Dec 12, 2010 | 11:30 AM
big78f150's Avatar
big78f150
never heard of this way. its not hard to take the spindle off. i dont know if it would be possible to do it without taking the axle off
Johnwb150
2010 - 2014 Ford SVT F150 Raptor
Dec 15, 2014 11:42 AM
2$bronco
1978 - 1996 Big Bronco
18
Mar 10, 2013 10:15 AM
rustynuts
Aug 19, 2009 05:50 PM
lonewolf1000
Feb 10, 2003 10:23 PM
