Notchy shift manual
Old Dec 3, 2010 | 08:08 PM
cmonkee's Avatar
cmonkee
Notchy shift manual
I have an 85 f150 300i6 with what appears to be the tremec t170ft trans. Code B on the door panel. Wanted to check the fluid but being under it i see nothing that looks like drain/fill plugs. Tried looking in the cab down through the shifter.
Is there some where else i can look or does this have to be dropped in order to check/change the gear oil?
Thanks.
C
Old Dec 3, 2010 | 09:54 PM
Franklin2's Avatar
Franklin2
You should have a fill plug on the side of the tranny about half-way up. If you do not have a drain plug, I know on the old 3 speeds you had to take the lower bolt out that holds the rear housing of the tranny to the main body of the transmission to drain the fluid out.
Old Dec 13, 2010 | 09:39 PM
nolan62's Avatar
nolan62
I believe I have the same tranny as you. The plug is on the Passenger side about half way down.
Old Dec 14, 2010 | 09:48 AM
1986F150six's Avatar
1986F150six
cmonkee,
Some shops have a vacuum pump and actually suck the fluid out through the fill hole, shown above.
My 1986 F150 with SROD transmission was balky when shifting, especially when cold. I changed the transmission fluid and used synthethic 75W90 and it made a great difference.
Old Dec 14, 2010 | 11:31 AM
89xproject's Avatar
89xproject
Post
i have an 89 f150 just did a trans swap went from the five spd M5r2 to the 4spd T170FT (Code-RTS) .. not sure what fluid it takes guessing gear fluid 80w???
brennanforgeron
Feb 2, 2017 01:45 PM
lalberts
22
Jan 11, 2017 10:16 PM
Norma stitz
Oct 16, 2016 10:30 AM
llh
Modular V10 (6.8l)
Oct 22, 2015 07:16 AM
shorinjin
Oct 30, 2009 06:49 AM
