coolant SCA
Old Dec 3, 2010 | 06:10 PM
jberrouard's Avatar
jberrouard
coolant SCA
I just bought a 2002 7.3 F350. I have been reading tons of threads on this forum and saw that coolant must have proper levels of sca. So I tested mine and it shows that I need to recharge it.
From what the test kit says I need about 2 pints. I am looking for a place to buy it and it seems like no auto parts stores like autozone or adavance has it. Do I need to go to the dealer?
Old Dec 3, 2010 | 06:19 PM
rcgtsport's Avatar
rcgtsport
napa has its called napa kool 4056 16oz bottle.
Old Dec 3, 2010 | 06:23 PM
jberrouard's Avatar
jberrouard
Thanks I would not have ever know that sca needed to be added to coolant in diesels with out this site.
Old Dec 3, 2010 | 09:55 PM
Bigcat350's Avatar
Bigcat350
Any of your large truck repair shops will have it also heres a little info.Part I: Choosing and Using a Supplemental Coolant Additive
Old Dec 3, 2010 | 10:02 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Nice link. Reps sent.
To the OP, here is the stuff I use. NAPA carries the SCA in pints, quarts and gallons so you can see which is the best value for your needs.
Old Dec 4, 2010 | 07:48 AM
jeronlines's Avatar
jeronlines
Same stuff as Greg. The PO had plain Jane green coolant so when I tested it showed recharge now. A full 16 oz bottle of Napa Kool went into the Degas bottle. I drove it around 20 miles, let it cool and rechecked. The strip showed perfect balance. That was around 2000 miles ago and no change. I check it once a month with the rest of the fluids, and when I drain the fuel/water separator.
Old Dec 4, 2010 | 08:40 AM
DND58's Avatar
DND58
To the OP, you might want to just change the coolant if you do not know the history of previous owner maintenance. The 02's came with the gold coolant, but many here have changed to a varity of the ELC's.
Old Dec 4, 2010 | 09:28 AM
helifixer's Avatar
helifixer
any WIX filter dealer should have it ( I think WIX makes it for NAPA ) as stated before any shop that deals with big truck stuff should have it.
Old Dec 4, 2010 | 06:54 PM
Yeti1234's Avatar
Yeti1234
Will someone please elaborate on why it's needed? Thanks! Nevermind, I found the link posted above, thanks!!!
Spool&Go
19
Oct 29, 2014 02:41 AM
One Sock
General Diesel Discussion
Dec 18, 2013 06:53 PM
scatgo
Nov 20, 2011 10:58 PM
Fourwheelinj1
Mar 25, 2007 10:53 PM
Lucca
Nov 21, 2003 09:01 AM
