Oil level question
Old Dec 3, 2010 | 04:13 PM
Innocent Bystander's Avatar
Innocent Bystander
Oil level question
When I got my new to me F250, the PO told me he would only put 14 qts at each change. He said with 15 he could tell the engine ran rougher. Anyone ever hear this?
Old Dec 3, 2010 | 04:22 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
14 quarts is about what it takes to fill up. You never get all the oil out of the engine and the oil cooler. As long as it shows full on the stick, you are good to go.
What type of oil and where do you live?
Old Dec 3, 2010 | 04:24 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
I have never heard that one before. I usually put 4 gallons in mine and that's 16qts.I t seems to run pretty good but then again I have never tried 14 qts?
Old Dec 3, 2010 | 04:42 PM
husker's Avatar
husker
Mine usually takes 13-14 quarts to show full on the dip stick with a filter change.
Old Dec 3, 2010 | 05:10 PM
Pocket's Avatar
Pocket
Mine also usually takes about 14 quarts at each oil change. 15 usually puts it right above the crosshatches on the dipstick.
Old Dec 3, 2010 | 05:37 PM
Innocent Bystander
Thanks for the replies. I live in Dallas and I'm switching from dino Motorcraft 15-40 to Rotella T6 @130k
Old Dec 3, 2010 | 05:48 PM
husker's Avatar
husker
I switched for the first time, 141,000 on the truck, this last oil change to T6 and am happy with it. The engine seems to run quieter and on cold days so far I haven't had the romps since the switch.
Old Dec 3, 2010 | 05:49 PM
Pocket's Avatar
Pocket
Shouldn't be a problem at all. In fact, the truck will probably start a little easier in really cold weather. Of course, that's Dallas.... so cold is what, 30 degrees????
Old Dec 3, 2010 | 05:51 PM
Ponyboychris's Avatar
Ponyboychris
Eh, more like 50 degrees....
14 or so quarts for me too.
Old Dec 3, 2010 | 07:55 PM
spunks00's Avatar
spunks00
with 210k on mine i over fill her a lil becuase i know she burns it, and it put about 15.5qts in each change. i think 15qts would be perfect on mine. i would just say keep an eye on your oil level i have let mine get low once and she didnt run very well till i topped her off
Old Dec 3, 2010 | 08:34 PM
jcrammell's Avatar
jcrammell
I run 4 gallons myself. Runs like a champ.
Old Dec 4, 2010 | 01:44 AM
orng1's Avatar
orng1
I use the 4 gal too but I tale about half a qt out the HPOP.
Old Dec 4, 2010 | 08:30 AM
WilsonTaylor's Avatar
WilsonTaylor
No, that's D@#* Cold around here. My wife starts complaining about 58. She wants to move somewhere warmer. Personally, I think about 40 is good camping weather.
Old Dec 4, 2010 | 09:50 AM
bpdad's Avatar
bpdad
With a long drain time, filter change, and emptying the HPOP I put 4 gallons in mine. It takes the level right to the full mark on the dipstick.
Old Dec 4, 2010 | 01:26 PM
blue1ton's Avatar
blue1ton
15 quarts brings me to the full mark wothout draining the HPOP.
