leacking fuel when cold
Old Dec 3, 2010 | 08:18 AM
jg96powerstroker's Avatar
jg96powerstroker
hey guys are work truck is a 99sd, and in the mornings when its cold it leacks fuel , it looks like its leacking on passangers side, vally pan has a little fuel in it, but when ist running it pours a stream out,sone duddys have said it was a water in fuel senser, others say fpr not sure though, my 96 did kinda the same thing last year and i think it was an oring in the fpr, not sure though, could use any help , wanna try and save them some money, ford gets 90 an hour i only get 30, well 15 shop time but beats being at home! thanks
Old Dec 3, 2010 | 08:55 AM
pbr man's Avatar
pbr man
Mine was doing the same thing. It is most likely your fuel drain valve leaking, but the other o rings on the fuel bowl could be leaking too. I went ahead and resealed the whole fuel bowl. It only took about an hour and now there is no more leaks. Here is the kit I used.
Replacement O-rings for Ford Diesel Engines
Old Dec 3, 2010 | 09:02 AM
cj45lc's Avatar
cj45lc
What he said plus look at the fuel lines where they run through the clips, they tend to rust &/or rub through from vibration
