6.0 in an Excursion
How do the two compare for power? Fuel economy? Reliability? Alternative fuels (specifically home-brewed biodiesel)?
Common sense tells me to expect the power to be a little better for the 7.3L and the fuel economy to be a little better for the 6.0L - but that isn't necessarily a safe assumption.
I'm looking at this mainly as a people mover - not a major towing rig. About the only towing I would expect to do with it is pulling a 2000 pound boat.
Given all that, I'm looking for recommendations. Is the newer 6.0L a more economical motor, that is powerful enough, and will handle home made bio?
7.3L
Peak Hp: 275 @ 2800 RPM
Peak Torque: 525 ft-lbs @ 1600 RPM
6.0L
Peak Hp: 325 @ 3300 RPM
Peak Torque: 570 ft-lbs @ 2000 RPM
7.3L
6.0L
What kind of fuel economy do they generally get?
Any particular weaknesses or problem areas?
I have a 2004 Excursion with the 6.0 and me and my whole family love it. It fits everyone comfortably and rides nice.
I've been averaging 15-16 city and about 17.5 highway. Been hand calculating every tank for about a year and a half.
Weaknesses or problems area that come to my mind immediately.
1. Maintenace is key with the 6.0 and you have to change the oil and fuel filters at the recommended intervals and use OEM, intertnational, or Racor filters.
2. EGR valves and coolers fail rather frequently. It's almost as though it should be a maintenance item. There are alternatives to replacing with OEM to reduce or elimate the issues but they cost money.
3. There seems to be a fair amount of FICM issues as well. This seems to be closely tied to battery voltage and overall health of the charging system.
I'm sure you'll get plenty of other good feedback from this site. I've learned a lot from lurking around this forum.
Good luck with your purchase!
My random thoughts are:
6.0 = has more power, pulls harder. Can be reliable, but maintenance is critical and you may still have some issues.
7.3 = No EGR, which is a problem area on the 6.0
6.0 = Not as forgiving with Bio-D. The 7.3 seems to burn about anything.
6.0 = Torqshift transmission. A major advantage over the 4R100 behind the 7.3.
7.3 with low miles will be harder to find, and expensive, all else being equal.
Fuel mileage always goes to the 7.3. Between 2-4 MPG better than the 6.0.
If you aren't going to tow heavy, and you can find a low miles Exc, the 7.3 would be hard to beat. IF you can find one.
If they had upgraded the Exc like they did the SD, with larger brakes, coil springs, updated interior, then my opinion would be different.
As for maint. I change the oil once a year with Rotella synthetic. I went with the synthetic because I only do it once a year and don't really put a lot of miles on it. I have all the original filters except the oil filter. I haven't changed any fluids but the oil. Still have the original tires with lots of tread left. I did have the turbo replace at 15k under warranty. This was really my fault since I never really put any miles on it and at the time we still had the dirty diesel. The new cleaner diesel fuel has really did away with most of the earlier issues the 6.0 had.
Did I say that I LOVE IT? Lots of power. Remember, every other SUV wants to grow up and be a diesel excursion. :-)
I've never seen a 6.0 that runs on home brew that didn't have injector problems. I only know a handful of guys that run it though. That's a specific question you should post to get replies from those with experience. 6.0 injectors aren't cheap, and the average guy can't rebuild them at home.
