Offroad & 4x4
Extended radius arm's or Drop Brackets
Old Dec 6, 2010 | 08:38 AM
alpha/omega's Avatar
alpha/omega
Originally Posted by rich.peterson
The increased ground clearance will help with logs and rocks that I might have to get over.
I love how people think lift kits increase ground clearance.
Old Dec 6, 2010 | 11:01 AM
fatdan460's Avatar
fatdan460
i can't wait till santa one day drops off my portal axles so i can tell people i don't have any lift
always wanted a set.
Old Dec 6, 2010 | 05:39 PM
alpha/omega
Seems like someone makes "bolt on" portal boxes for a D60F/D70R.
Id be more in favor of that due to the vast availability of parts for the Dana axles vs anything for a unimog.
Old Dec 6, 2010 | 05:43 PM
captain p4's Avatar
captain p4
approach departure and breakover
But tires do all that and help ground clearance (that's the part under the axles .. I know you know that Kris, it's for all the kiddies ) While keeping you're COG low if you don't lift it a brazillion feet in the air.
Old Dec 6, 2010 | 05:46 PM
alpha/omega
wait...
Are you saying a lift kit doesnt lift the axle?
Old Dec 6, 2010 | 05:48 PM
captain p4's Avatar
captain p4
Correct.
Sorry, I meant to say lift kits increase approach, breakover, and departure, but do not increase ground clearance.
Tires increase all of it.
Old Dec 6, 2010 | 05:51 PM
alpha/omega
this floors me.
Old Dec 6, 2010 | 05:57 PM
captain p4's Avatar
captain p4
wat
Old Dec 6, 2010 | 06:07 PM
alpha/omega
Im learning so much. I <3 FTE!
Old Dec 6, 2010 | 06:16 PM
captain p4's Avatar
captain p4
**** awph! I'm helpin newblets
Old Dec 6, 2010 | 08:07 PM
kjett's Avatar
kjett
Yeah, but ur still a turd burgler
:flipoff
Old Dec 6, 2010 | 09:54 PM
fatdan460's Avatar
fatdan460
i think portal boxes on tons would be sweet, but overkill. it'd be better suited for half tons, gets you that little bit of extra ground clearance, and you don't need to worry so much about ring and pinion strength with portals. you'd be using some numerically low (high) gear set because it would be multiplied by whatever hub ratio, usually a 2 to 1.
d44/9'' 2.50-2.75 gears and a set of 40's=PORTALWIN!!!!!!
Old Dec 7, 2010 | 02:10 AM
  #28
hav24wheel's Avatar
hav24wheel
No Dan, tons better just cuz they r bigger
U would still have them tinny ball joints on the half tons. Add the leverage of portals( its almost like running a huge lift block) and the half ton front not up to the job.
Old Dec 7, 2010 | 10:39 AM
  #29
fatdan460's Avatar
fatdan460
yeah, well i like tacos
Old Dec 7, 2010 | 10:41 AM
  #30
hav24wheel's Avatar
hav24wheel
lmao..........
