View Poll Results: How many people seen starting issues
vb code
0%
smiles
0%
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
2002 Ford Ranger starting issues
Old Mar 1, 2003 | 11:49 PM
jonpe58's Avatar
jonpe58
Question 2002 Ford Ranger starting issues
jpe@cableone.net jpe@cableone.net
I have a 2002 Ford Ranger XLT long bed with the 3.0 V6 and 5 speed auto tranny. It has been doing great until the transmission failed at 8500 miles which turned out to be a defective/cracked servo in the transmission which was replaced under warranty by the dealership.
It works fine now except about a week ago, it started have troubel starting all of a sudden just out of the blues and I thought it was bad gas and I put some fuel injector cleaner fluid in the gas tank thinking it might clear any water there might be in the fuel injectors but I doubt that now since I have since refueled at a different gas station and it still has starting issues. It will start ok in the mornng when cold but when I go to some place like work and let it sit for a couple of hours until lunch and then it will have trouble starting and makes this clankety clank noice (can't desribe noise) but will crank for about 4 or 5 seconds before it will finally start and sometimes will not run after starting and would have to start it again and it would seem to barely start and would run a little rough after starting. it seems to run find after I get it started and let it idle for a minute to allow it to straighten out. I use the 5w-20 synthetic blend which is what came iwth it from the factory. I checked th oil this morning and it was dark and think looking which I guess is normal for cold synthetic blend oils (only has 2500 miles on the oil. Anyone out there seen starting issues like this on their 2002 rangers?
Old Mar 2, 2003 | 12:01 AM
Mil1ion's Avatar
Mil1ion
Wrong forum in wrong format!
onetonford1
New Member Introductions
Sep 6, 2018 10:51 AM
ghunt
May 8, 2011 08:16 PM
Bu||Dog(CA)
Nov 1, 2006 02:41 PM
daywalker
21
Mar 10, 2001 03:51 PM
