dt466 question
Old Dec 4, 2010 | 09:56 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I just took your engine hours, then subtracted the PTO hours and came up with an average spped of 30 MPH to get your total mileage.
Given the PTO time and the low average speed, that engine don't see a real load on it for a very high percentage of the total run time.
If that were an old school mechanical diesel I would suspect damage like you would find in a wet stacked diesel.
Rings gummed up, cylinders washed down and possibly worn valve guides.
Does that engine raise the idle RPM and close the back pressure valve if it has one to keep the engine temps up like the Strokes do?
Don't know much about the 466, but one of the local masonry supply places have a bunch of them.
Their trucks seem to have a lot more pep than what you show in the video.
They normally have about 10 tons on for loads on their dump trucks.
Old Dec 4, 2010 | 10:11 PM
RRranch's Avatar
RRranch
Look at your fuel filter. It will be black as your oil if it's o rings.
Old Dec 5, 2010 | 01:58 PM
rideracelivemx7's Avatar
rideracelivemx7
Injector orings would put oil in the fuel? I'll check the filter next thoe, and there is no ebpv in these trucks, turbo is tiny Thoe, depressing!
BGF100
Mar 1, 2017 08:59 PM
parkland
General Diesel Discussion
140
Sep 24, 2016 12:47 PM
deshet1980
Large Truck
Sep 11, 2015 08:48 PM
wirelessengineer
May 17, 2015 05:28 PM
Racecarhauler
Oct 20, 2009 01:41 AM
