General Diesel Discussion
94 7.3 not starting
Old Dec 1, 2010 | 05:57 PM
dwracing's Avatar
dwracing
94 7.3 not starting
replaced fuel lines at fuel pump down to main steel lines because of rubed hole due to safety clamp on fuel line. Can't get started. Cranks great with new starter and batteries charged and fresh oil change and new fuel filter. Any Help?
Old Dec 2, 2010 | 03:14 AM
Midwest Dually's Avatar
Midwest Dually
Check your fuel bowl. Make sure there is fuel in there first. Fill it up, then crank.. if not you will burn your starter out trying to get it up and going. Make sure your fuel lines werent switched with the return lines. By filling the bowl you prime the engine. There is enough fuel in the bowl to keep the engine running until the fuel pump catches up!
Old Dec 2, 2010 | 10:23 AM
dwracing's Avatar
dwracing
Thanks For The Tech Reply On My No Start Condition. I Have Filled The Fuel Res Bowl And Have Good Pressure At Shrader Valve.
Old Dec 2, 2010 | 07:16 PM
sandmanf250's Avatar
sandmanf250
starting a 7.3
batteries must be up to snuff and starter must spin her over really fast.some wheres around 1200 rpm.
Old Dec 6, 2010 | 01:03 PM
dwracing's Avatar
dwracing
Thanks, The Starter Is New And The Batteries Are Very Much Charged And The Engine Cranks Over Very Well. Still No Start?
Old Feb 6, 2011 | 10:47 AM
sodbuster608's Avatar
sodbuster608
ANY SMOKE AT ALL IF YOU ARE IN COLD WEATHER PLUG IN THE HEATER IT WILL CRANK FASTER
Old Feb 6, 2011 | 10:50 AM
sodbuster608
ALSO WITH OUR BIG KW HAVE PUT TRANS FLUID IN FILTER ADOUT HALF FULL DONT NOW WHAT IT DOES BUT WORKS
Old Feb 6, 2011 | 02:00 PM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/9...rt-advise.html Have a read through this link. May help if you have an IDI diesel.
