1990 F350 sending unit back flow value and screen
Hi I'm new to this site. I have a problem with my 1990 F350 front fuel tank sending unit back flow value and screen (sending unit working fine) It's the screen and back flow value that is broken off..
I can't locate the back flow value and screen or even the whole unit.
I went to the parts counter at Ford and they said they didn't have one or find one. However, this dealer has never been very helpful.
Question: is there a back flow value and screen I can attach to the tube of the sending unit that will work for a diesel tank.
Thanks in advance.
Joe
Thanks in advance.
Joe
By "back flow valve" I assume you mean check valve or non return valve? Did not know there was such a thing on a diesel. However if this is the fuel pickup pipe that has broken (not uncommon) most guys just cut a V in a length of fuel proof pipe, push it over the broken pipe and secure with a hose clamp. If you want to reuse the broken off piece you could rejoin it with a short length of hose and two clamps.
The new unit came today. I got it from a dealer in PA.
Everything with the new wire connector and Shipping $340.00
If it was not for the valve I would have just put a hose on the end.
It came in one day with ground service (UPS)
I could not find the part on the site you recomended.
I don't know how to post Pictures of the unit.
I will post after it's back together.
https://www.ford-trucks.com/forums/1...pics-here.html Here is a link on how to post pics. Unless you pay the $20.00 to become a "supporter" you cannot post directly from your computer.
Sometimes I think it may be worth being a supporter as you don`t get bombarded with ads and you have access to the unrestricted pages.
However glad you got the part. Partsguyed maybe doesn`t have everything but he is hard to beat for OEM Ford parts, if available.
JoeVR5
07-18-2010 01:07 AM
joepechin
05-25-2006 10:54 AM
drharrison
06-05-2001 03:53 PM
