Plug-in Heater
Old Dec 1, 2010 | 09:13 AM
jle70's Avatar
jle70
Plug-in Heater
Heater seems to be not working. What should I check? Yes, the power cord works. LOL
Does this heat block only or both block and oil?
Old Dec 1, 2010 | 09:16 AM
Talyn's Avatar
Talyn
It heats the engine coolant.
It goes into the motor right at the Oil Filter thingicannotrememberwhatthenameisthingy.
They are fairly easy to replace.
Old Dec 1, 2010 | 09:18 AM
CampSpringsJohn's Avatar
CampSpringsJohn
It heats the block. I would check the cord, look for a bad spot in the power cord, or possibly where it plugs into the heater.
Old Dec 1, 2010 | 09:25 AM
jle70's Avatar
jle70
Obviously it should read 115+/- volts and the end?
Anyone know of a good oil heater?
Old Dec 1, 2010 | 09:54 AM
CampSpringsJohn
I'm not familiar with oil heaters. But if the block heater is working, that's all you need. Our trucks will start with temps in the single digits as long as the glow plugs are working. I'll admit, they may not like starting when it's that cold, but they will. Also a good fuel additive is a good idea when it's that cold. I like to use the block heater when it gets below 25. I have mine plugged in a timer that kicks on about 2 hours before I leave. It also helps make heat in the cab quicker!
Old Dec 1, 2010 | 10:00 AM
jle70's Avatar
jle70
Reason I ask is, it's been 20's at night and I have to crank 10-15 secs at a time and about 10 times to get it going even with heater plugged in. One reason I know, I am removing 15w40 tonight and putting in 10w30. I usually have it done by now. But I never had these issues with it plugged in before.
Old Dec 1, 2010 | 10:06 AM
CampSpringsJohn
That's way too much cranking. I would say your block heater ain't working as well. But I also suspect you may have a GPR not working. How long does the WTS light stay on when you turn the key?
Old Dec 1, 2010 | 10:12 AM
JamesHajek's Avatar
JamesHajek
When was the last time you changed glowplugs? Thats way too much cranking, Mine will start in single digits without being plugged in. It will romp a bit cuz i still have 15w40 in mine but it will start. Also, how old are the batteries?
Old Dec 1, 2010 | 10:18 AM
kawa's Avatar
kawa
Talking
I don't think that changing the viscosity of the oil will solve your problem. That will be a band aid fix if it helps at all. Fix the problem not the symptom. JMHO
Rog
Old Dec 1, 2010 | 10:20 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Agree with that, maybe your GPs also are not working properly.
I guess you could test the block heater, unscrewing it from its base, but Im not sure if it is possible and if you loose to much coolant or oil?? I hope somebody chime in here later.
Old Dec 1, 2010 | 10:22 AM
CampSpringsJohn
I run synthetic 15w-40 year round in my trucks. Last year saw some sub zero temps and no issues. I just add some anti-gel when it gets that cold just to be safe.
Old Dec 1, 2010 | 10:45 AM
Talyn's Avatar
Talyn
Fuel has been bad in my area, my cold starts are just ridiculous compared to last year when I was starting at 5 outside with no issues.
Old Dec 1, 2010 | 11:05 AM
mq1shooter's Avatar
mq1shooter
Check the Amp Draw...
Other than obvious items, wires, plugs, etc. Plug it into 120V and find an A/C Amp meter and see if it's pulling amps...Mine checked out to be about 8.7 amps and that equates to 1000 watt's...
Old Dec 1, 2010 | 01:55 PM
madpogue's Avatar
madpogue
The WTS light time is irrelevant; it's controlled by the PCM and (unless it's a CA truck) there's no feedback from the glow plugs to the PCM. If you want to let the glow plugs to work longer before starting, you don't have to do anything; just leave the key in RUN for a few seconds longer. If that makes starting easier, then indeed, you may have one or more bad GPs or a weak GPR.
An in-line power meter like this: Digital Electricity Usage Tester or this: Weems Creek Solutions - Product - Kill A Watt makes it easy to diagnose block heater problems.
Old Dec 1, 2010 | 03:03 PM
jle70's Avatar
jle70
By the volt meter, the GPs stay on for several minutes. The wait light 10-15 secs.
