Plug-in Heater
Old Dec 1, 2010 | 03:12 PM
78pace's Avatar
78pace
You should be able to hear it working by the drivers side tire. Mine I have to move the connector on the block plug then it starts heating. Sounds like a hissing noise. The cord is cheap I think like $15 to replace.
Old Dec 1, 2010 | 03:19 PM
mq1shooter's Avatar
mq1shooter
WTS times vs. GPR on-Times
Old Dec 1, 2010 | 03:21 PM
Hussler's Avatar
Hussler
Measure the resistance on the two flat prongs on the power plug. Should be between 10-20 ohms. Last time I checked mine measured 14 ohms.
Old Dec 1, 2010 | 03:40 PM
CampSpringsJohn's Avatar
CampSpringsJohn
On my trucks when it's cold out, the WTS light will stay on for a good 30 seconds. I will usually wait another 15 to 30 before I even try to crank it. You might have some glow plugs not working.
Old Dec 1, 2010 | 04:08 PM
jle70's Avatar
jle70
Plug-in Heater cord.
Well, I found out what is wrong with it.
http://cid-11c122a2edc4a553.photos.l...r/DSC00054.jpg
Old Dec 1, 2010 | 04:56 PM
CampSpringsJohn
DSC00054.jpg - Windows Live
Just tape it! It'll be good! Just kidding! Looks like a trip to the parts store is in order.
Old Dec 1, 2010 | 04:59 PM
jle70's Avatar
jle70
Ford or NAPA?
Old Dec 1, 2010 | 06:36 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Heater seems to be not working. What should I check? Yes, the power cord works. LOL
Does this heat block only or both block and oil?
Im confused what happended?
Glad you found out your trouble.
Old Dec 1, 2010 | 06:51 PM
madpogue's Avatar
madpogue
Fried cord. There are generic replacements.
Some of 'em crackle/hiss. The one in our ECLB cracles; the one in the SCLB doesn't. They both heat, though.
Old Dec 1, 2010 | 06:57 PM
Copedawg's Avatar
Copedawg
I don't know what you are showing. It is obviously bad but I can't picture where it should be.
Old Dec 1, 2010 | 07:01 PM
marks500's Avatar
marks500
I have never plugged mine in before, and from the looks of it the previous owner never plugged it in either. Since its getting cold I want start plugging it in. Should I keep an eye on it the first time I plug it in? Is there any Fire Hazards with these Block heaters? I just didnt know since the block heater has never beeen used. I am sure its fine, Just wondering, want to be safe.
Old Dec 1, 2010 | 07:16 PM
Copedawg's Avatar
Copedawg
I would clean the plug real good (get all the green stuff out). spray contact cleaner and scrape it out then spray some more. You most likely want to use a GFI outlet (like all outside outlets should be). Make sure you have a heavy duty extension cord like 12 AWG or lower (10 AWG). I normally run the cord under the tire so in case I forget to unplug it the tire will unplug it for me (It has happened before and unfortunately it may happen again). Turn the power off then unplug it and never start it while plugged in. Also leave your defrost in the "ON" position, this way you will not have to scrape your windshield in the morning.
Enjoy your easy starts in the morning!
Old Dec 1, 2010 | 07:26 PM
  #28
marks500's Avatar
marks500
Thanks man, This Green stuff you are talking about is? it is on the end of the plug? I do use outside outlets that do have the Surge protection thing. My truck stays parked in the street so I cant forget to unplug it...lol.. I would have never known to unplug it before starting.. whats the problem with starting it plugged in?( I will never do it, just curious.)
Old Dec 1, 2010 | 07:39 PM
  #29
Copedawg's Avatar
Copedawg
If the plug has not been used before it most likely has a greenish goo in it (tarnish from brass/copper). There is a danger of some sort (I am going by memory) by starting it while plugged in. I do not remember the "exactlies" of it but someone will help refresh my memory....It was a long shot (danger) but I still do it (after reading about it). See how bad my memory is?....this is why I run the cord under the tire, lol!
Oh, and use common sense while plugging in in the cold rain and snow.
You will like the plug in method I am sure.
Old Dec 1, 2010 | 08:31 PM
  #30
Copedawg's Avatar
Copedawg
Found on another forum:
"Yes, you can blow the heater right off due to thermal shock. It is not common except up nor't where it is COLD, but beware that it *can* and does happen.
When the block heater is on, the coolant around it is much warmer than that in the rest of the system. When you start the engine, COLD coolant circulates thru the block, and when it comes in contact with the heater element, you can wreck it."
