Running Rough
Old Dec 1, 2010 | 07:45 AM
wbhess's Avatar
wbhess
Running Rough
Just bought an 88 f150 4x4 5.0 fi with the 4spd w/od. Its not inspected yet but I drove it around maybe 10 miles so far. Yesterday as I was driving to the garage under 3/4 throttle, the truck just bogged down. It still ran and started but it felt like it was running out of gas but there was still plenty. It was raining out so Im thinking the excess moisture was at fault. The truck is old so I might try an ignition tune up with new coils, wires, plugs? Or is there something else I should try first. There are no check engine lights or other warning lights on
Old Dec 1, 2010 | 08:03 AM
rockin300's Avatar
rockin300
change your fuel filter and you basic tune up
Old Dec 1, 2010 | 12:11 PM
Hotshot869's Avatar
Hotshot869
I agree with Rocking, basic tune up, Spark Plugs, Wires, possibly check Coil, and Distributor Cap/Rotor, Air and Fuel Filters.. Then If it still acts up, check the Timing, and then move onto sensors like TPS, IAC, CTS, and O2
Old Dec 1, 2010 | 12:48 PM
rockin300's Avatar
rockin300
my truck boggs down i just stored it for now
Old Dec 1, 2010 | 02:37 PM
wbhess's Avatar
wbhess
I was hoping that I didn't burn a ring or something in the engine. It idles fine but 2k-3k and higher it sounds boggy. I noticed the oil pressure was a little low too but then restarted the truck and it read normal
John Clugston
Jan 30, 2013 06:10 AM
nateraz1
Dec 11, 2012 10:26 PM
Benjoman
Aug 6, 2007 10:09 PM
984x4F150
1997 - 2003 F150
18
Sep 24, 2003 05:58 PM
