Oil pressure gauge is really an idiot light?
#31
#33
#35
#36
#37
#38
#39
If you can find the two traces on either side of the resistor, you can just solder a jumper parallel to the resistor. You really don't have to take the resistor out, (especially if you can't get to it...). If you add resistors in parallel, it will decrease the resistance, so adding another resistor will make the needle go higher. You can play around with different values to get the needle right where you want it, but the cheap electrical gauges fluxuate so much, it's hardly worth it.
Which leads to the story I alway heard about why Ford went to the idiot light gauge. Because the cheap electrical gauges fluxuate so much, people with new Fords were bringing their cars/trucks in for warranty every time the gauge would change from "normal". The techs could find nothing wrong and were eating shop time. Instead of Ford installing expensive accurate gauges, resistors cost less than a penny and no more warrenty problems.... If a customers gauge showed 0, they really had a problem.
#40
Howdy that is exactly how I have converted these before is to
solder a jumper across the the resistor using the existing solder at either end. I heat these just enough to get the solder to puddle and accept the jumper which I have already tinned. And yes the newer gauges move extremely quick mine takes about 1/2 second to move to half gauge after a startup even cold. I know that 5w-20 is close to water consistancey but this is rediculous.
#42
#43
on my 99 ranger 3.0 FFV it takes about 5-6 minutes before my oil pressure gauge moves then jumps up to the middle setting, flickers back and forth a few times and then stays in the middle... could this be the sending unit or the gauge acting up?
#44
#45
ford_racing_4_life, kinda sounds like the sending unit, they are a common problem.
Before relacing it, check it's wires electrical connection, (should be clean & tight) & case continuity to ground, on the off chance there may be a poor connection through the sending units threads to the engine block.
Let us know how it goes.
