Rear end fluid question
Old Dec 1, 2010 | 01:05 AM
XBAJBUSX's Avatar
XBAJBUSX
95 f250 psd 5 spd 4x4 I want to change my fluid but I'm not sure what fluid I need my little tag on the rear end is gone so I can't tell what I have .it has 12 bolts can someone help me out here
Old Dec 1, 2010 | 01:23 AM
Muktown's Avatar
Muktown
You have a sterling 10.25" rear axle. It should take 75-140 synthetic. They have it at walmart at least that's what I use and it already has the friction modifier in it in case you have the limited slip. It was an option. Im not sure about the obs but on super dutys the axle code is also on the door
Old Dec 1, 2010 | 06:05 AM
427 fordman's Avatar
427 fordman
It's on the door on our trucks too. C9 is limited slip and 39 is unlimited slip
Old Dec 1, 2010 | 07:37 AM
XBAJBUSX's Avatar
XBAJBUSX
How many qts???
Old Dec 1, 2010 | 07:39 AM
plgebbia's Avatar
plgebbia
its something over 3 quarts, so you will need a gallon. Make sure you use the friction modifer additive if you have limited slip.
Old Dec 1, 2010 | 08:26 AM
tbone heller's Avatar
tbone heller
+1 Just because the bottle of fluid says that it can be used in a limited-slip differential does not mean that it already has a additive in it. You have to use a friction modifier if you have limited-slip.
Old Dec 1, 2010 | 09:01 AM
XBAJBUSX's Avatar
XBAJBUSX
Where I get one
Old Dec 1, 2010 | 04:17 PM
RRranch's Avatar
RRranch
Ford dealer is best for the additive. I think it was 2 of those little bottles they have that you need. Parts stores have it too but Ive never had good luck with it. Or you can use royal purple. They claim it has it in it already. I used it and the clutches are working like they should.
Old Dec 2, 2010 | 12:34 PM
XBAJBUSX's Avatar
XBAJBUSX
Ok so I check my rear end is C9 what do I need and how much
Old Dec 3, 2010 | 03:53 PM
XBAJBUSX's Avatar
XBAJBUSX
What fluid you guys recommend for the C9 ???? Help me out here gone due this next week
Old Dec 3, 2010 | 06:26 PM
427 fordman
Royal Purple is good stuff. Whatever you use you need to have the friction modifier in it or added. I think its 3-4 quarts. Synthetic 75/140
Old Dec 3, 2010 | 07:06 PM
pjwoolw's Avatar
pjwoolw
Redline synthetic. 75/140. Has the additive for the limited slip but there is a version of the oil that doesn't have the additive so check the label. Best there is. Use a gasket and Gasgacinch sealer. Follow the instructions on the can. It will never leak. Tighten the bolts in cross pattern. Torque to 20 ft lbs or so. Put a little gasgacinch on the bolts too. After you fill it drive a few miles and recheck the fluid level.
Ford4Life04
2004 - 2008 F150
Jun 16, 2016 08:51 PM
rworld
Jan 18, 2016 02:37 PM
Myfreeford
Aug 10, 2014 02:08 PM
Myfreeford
Aug 5, 2014 10:03 PM
RobertJohn
Nov 21, 2010 10:35 AM
