91 f150 wont turn right
thanks for the reply ive never had a steering gear box go out so i dont no what it would feel like ,the tie rod ends and drag likn look ok the thing feels like no power assist turing right and fine assist turing left if that is a gear box thing is it a adjustment or a worn out part/gear,or did i get a bad rebuilt steering pump
I had the same problem a few years ago, turned to one side fine but no assist to the other.
It was with a reman steering box, naturally it was 1 month out of warranty. I tore apart and there are four or five square cut o-rings on the shaft going into the box, one was rolled around but I guess with high mileage yours are just worn.
You could buy a box for about $250 or fix yours if you feel OK with that and buy a seal kit for about $40.
Only special tool you'd need is a pitman arm puller.
If you do do it yourself, just watch the little ***** when you disassemble.
Good luck.
Aaron
Good luck.
Aaron
jmuenchow
28
07-03-2015 06:28 PM
charlesinks
01-18-2015 02:06 AM
Realtree91
New Member Introductions
09-11-2014 02:17 PM
chewy-man
02-13-2006 11:26 PM
