MTE Display
Old Nov 30, 2010 | 04:29 PM
porthole's Avatar
porthole
Originally Posted by Champ198
If we can have the fuel tank size changed in the ECM and Ford offers a larger sized OEM tank on 2012 short bed trucks (that can be retrofit), I may buy a Ford tank, install it and have the dealer change the ECM. I'm excited to see that this may be a possibility.
No doubt the cost would be double of either of the two aftermarket options.
If you guys are serious about tank size, you can't let the gauge issue dictate your decision.
The larger tank is so much more convenient then the inconvenience of the gauge.
And I'm sure we'll soon hear form those that have done it, maybe it is not off all the time. With my previous truck the gauge was only wrong for the first half.
Just use the "fuel used" display.
Old Nov 30, 2010 | 05:18 PM
EpicCowlick's Avatar
EpicCowlick
The fuel gauge works fine. It just moves half as fast. The fuel level low warning comes on with about 9 - 10 gallons left in the bigger tank.
Old Nov 30, 2010 | 05:54 PM
porthole's Avatar
porthole
That's why I wonder what all the concern is about.
rickatic's Avatar
rickatic
As another Titan owner, Epic...is correct.
Old Dec 1, 2010 | 02:20 PM
djjoshuad's Avatar
djjoshuad
I don't think it's real *concern*, but I personally have not considered a new Titan tank because I like the functionality of MTE, MPG, low fuel, etc. Even if they're not perfect estimations, I'd rather not have to do math in my head every time I look at the dash
I don't mind stopping more often to compensate for the 26-gallon tank. At least not enough to lose the other functionality. With this update though, we could have the best of both worlds.
Old Dec 1, 2010 | 02:41 PM
Scootimus's Avatar
Scootimus
I ordered my tank last night. This update would just be an added bonus!
Old Dec 1, 2010 | 08:21 PM
AlexWV's Avatar
AlexWV
Yep. That's exactly the way I look at it.
The MTE being wrong won't be a show stopper for me when the Titan tank comes out for the LWB trucks. But if we can get the tank size programmed that'll just be icing on the cake.
Old Dec 1, 2010 | 09:47 PM
rickatic's Avatar
rickatic
I have had the Titan tank for several fill ups now. Truck has 17500 miles on it now. My low fuel light consistently comes on with 10 to 11 gallons left in the tank. The gauge shows about a small eighth of a tank. My trip computer is always within 1.5 gallons of actual fuel used. When the low fuel light does come on, I have over 125 miles of range before I would worry. I usually get fuel at the next well priced place after the light comes on. The only thing that is not accurate enough for any purpose I can think of is the MTE. When it is at zero I still have 7 or 8 gallons left. No big math skills needed to keep track of fuel.
Old Dec 1, 2010 | 10:17 PM
EpicCowlick
Exactly my experience.
Old Dec 1, 2010 | 10:32 PM
porthole's Avatar
porthole
Does the 6.7 have an easy acces prime pump?
Old Dec 1, 2010 | 11:03 PM
kper05's Avatar
kper05
Do you mean to prime the fuel lines?
If I'm thinking of the same thing, it's a simple flip of the key to the on position (do not start engine), wait 30 seconds, turn off then repeat six more times.
After changing the fuel filters, the OM says to do that seven times (3 1/2 minutes total). Always read the OM to verify for yourself.
EDIT: Actually, it is only six times total. Oh well, seven won't hurt either!
Old Dec 1, 2010 | 11:08 PM
rickatic's Avatar
rickatic
...and why would we need it? The tank holds 51 gallons of fuel. The mileage computer has not been off more than 1.5 gallons in 17500 miles. That equates to roughly 25 miles of range discrepancy. There is 10 to 11 gallons of fuel remaining when the light comes on. That is a 100 miles of driving with 50 miles of reserve after that. I found out by accident that the truck would go 60 miles beyond the MTE = 0 reading when Deb took the truck. This tells me that the stock setup is also conservatively calibrated. If one knows there is consistently 10 gallons of fuel when the light comes on, how do you run out of fuel? With all that said, I am eagerly awaiting the arrival of fuel tank size re-calibration capabilities.
Regards
Old Dec 2, 2010 | 07:51 AM
  #28
Marauder92V's Avatar
Marauder92V
Regards
This conversation reminds me of the fuel system in small airplanes. The FAA mandates that the gauges are accurate at 1/2 empty (1/2 full if you are an optimist ). Not a real comforting feeling knowing this... That is why we small plane jockeys stick our fuel tanks during pre-flight and calculate our burn rate manually as opposed to trusting the gauges. And some of us go a step further and equip our plane with fuel totalizers that measure actual fuel flow and calculate it for us.
Old Dec 2, 2010 | 09:20 AM
  #29
rickatic's Avatar
rickatic
let's not even drag small airplane fuel systems into this discussion...Maurader is right...fuel calculations there make the Titan monitoring issues a total non-issue...and I won't fall out of the sky if I make a mistake on reserves in my truck
pbruckne
6.7L Power Stroke Diesel
17
Jan 5, 2020 07:45 AM
saltfisherman
Jan 10, 2015 08:04 AM
Str8shooter
16
Jul 17, 2012 09:33 PM
Marauder92V
21
Jun 11, 2011 09:06 PM
scott@superchips
2004 - 2008 F150
May 28, 2010 11:19 PM
